Question about Computer Associates Anti-Virus Plus Anti-Spyware 2008 for PC (757943328080)
I cannot uninstall parental lock it doesn't accept any passwords
  • 61 Answers
Firstly if your parents put some restriction than that is for your well being.
but i have to help you so just delete some files associated with it the software automatically stops working.
Posted on Nov 21, 2009
How do i unlock channels on sankey lcd tv model CLCD - 3236?
Parental control is enabled by entering a user-selected password. If this was done in the past, that password would have replaced the default password of 0000.
May 16, 2014 | Panasonic CT-24SX12 24" TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I do not have the webcam password . how do i retrieve it
I would suggest just removing the parental controls altogether.
1. Click the Start (Windows 7 Button) Button in the bottom left.2. Click on Control Panel3. Click on Uninstall Software (bottom left of the Control Panel)4. Scroll through the list and find the Parental Software5. Select 'Uninstall' on the top bar, right above the list of software.
Another option would be to uninstall the webcam driver and reinstall as a new piece of hardware. This will make the computer think it's a brand new device and the parental control would not carry over.
Dec 06, 2011 | Dell Vostro 1310 Notebook
I need the code for rca xl100
Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you forget your password, press the following buttons on the remote,
one by one: MUTE, DISPLAY, CLEAR, and RESET (you must be in the
password entry screen). Parental controls will then unlock and you can
re-enter a password via Lock Parental Controls.
If you need the manual please let me know.
Feb 06, 2011 | Televison & Video
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Parental control
Try this Hit "Menu" and go select the "Lock" sub-menu. It should ask you for a password. Initially the password for the US sets are set to 0 - 0 - 0 - 0.
If that does not work try 7 - 7 - 7 - 7. Once it accepts your password see if you have any locks enabled and turn them off.
Mar 05, 2009 | Akai Televison & Video
PARENTAL LOCK?
are you the parent or the kid if your the kid none of use are going to bea ble to help thats between you and your parents if you are the parent then...ther really is no way to get rid of it with out the password
Jan 08, 2009 | RCA F27625 27" TV
Parental controle
I have three users on my computer, and somehow I don't have an administrative user so I can change my parental controls or accept updates. How do I re-establish an administrator so I can accept program updates. I get a window telling me I need a password approval but there is no where to input the password. I have an HP and Windows Vista.
Jun 19, 2008 | RCA TruFlat 27F520T 27" TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Computer Associates Anti-Virus Plus Anti-Spyware 2008 for PC (757943328080) Logo
238 people viewed this question
Top Computer Associates Computers & Internet Experts
Alun Cox
k24674
Are you a Computer Associates Computer and Internet Expert? Answer questions, earn points and help others
