Question about Acer F900 Quadband 3G HSDPA GPS Unlocked Phone Smartphone
It has cracks in different colours but the screen isnt cracked
My LCD TV has developed about twenty different coloured lines down one side of the screen, can anybody tell me if I can fix this.
sounds like the Tcon board is causing the lines which is very common issue when the Tcon fails. You can get the replacement Tcon form www.tvrepairworld.com
Apr 05, 2013 | Televison & Video
My daughter threw a toy at the tv. The TV is not cracked but the is a splash colour on the screen. can it be fixed/
Hi, Unfortunately this is a crack internally, the spalsh of colour is the Liquid Crystals running through the cracks, the cracks can be very fine and not visible because of the spread of liquid. this can't be fixed, it would require a new screen which could be very expensive if you can get one.
you could try claiming on household insurance if it covers for things like this.
Hope this helps.
Feb 13, 2011 | Samsung LN32A330 32 in. LCD TV
Object hit TV screen and now picture looks like a cracked window even though the screen isnt..
Hi, If it looks like a cracked window then it most likely is cracked. this could get expensive to fix if the parts are available
Sep 10, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Coloured lines all over screen
The colored line you saw was the actual screen pressing against the back of the psp......Example would be if you put your thumb and pressed on a laptop's screen. It doesnt work now because the screen is now cracked and you can either order a replacment screen on amazon for about 50 bucks or buy a new system
Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
Crack inside of screen
This screen has multiple layers of plastic before you get to the main screen, if the picture isnt affected, you've only cracked oneof the plastic pieces, these are cheap to replace
Dec 31, 2007 | Philips 51PP9100D 51 in. Television
Colour interestingly different!
Change posistor in the degausing circuit.
Dec 22, 2007 | Toshiba 28N33 28" TV
Screen cracked and cannot taggle to seperate screen
Carefully examine the keyboard. These do vary from model to model but one key will have a screen symbol in another colour[blue perhaps] this will mean pressing another key to get the blue function The key to press may also have a blue element. Also get onto the Sony Technical Support team
Jun 06, 2007 | Sony VAIO TR3A Notebook
Two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Sep 24, 2006 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Acer F900 Quadband 3G HSDPA GPS Unlocked Phone Smartphone Logo
44 people viewed this question
Top Acer Cell Phones Experts
Computer Repairing
Computer Repairing
Thomas Perkins
Thomas Perkins
rey francis basa
rey francis basa
Are you an Acer Cell Phone Expert? Answer questions, earn points and help others
