Question about Samsung U900 Soul Cellular Phone
Camera stopped working - now phone won't turn on Is there any way I can reinstall software?
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
Pinnacle studio 14 importer has stopped working. It won't load up.
I have experienced this before with earlier versions of Pinnacle Studio. Sometimes a simple reboot works, other times I had to reinstall the software. Remember to backup all of your existing projects, videos, and pictures before you attempt to reinstall so that you do not lose them.
Jun 14, 2011 | Pinnacle Studio Ultimate 14 for PC
My Kodac Play Sport won't turn on. It won't charge either.
who bought this Kodak camera had the same problem!!!! i bought it.. then couple of months past..and would not turn on! I tried everything!! with my phone\'s charger it finally charged ..i let it charged for 3 hours then it still wouldn\'t turn on! :(
! never! buy this again!
Jun 02, 2011 | Kodak PlaySport HD
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
My built in camera has stopped working on my Samsung R530 - how do I fix it!?
THAT HAPPENED TO ME! And now it just won't come back! every time I open Play Camera it says 'there is an invalid argument' so i got a new webcam and it doesnt register. I tried uninstalling and reinstalling play camera but it just doesn't work at all! STRESSFUL -.-
Aug 12, 2010 | Samsung NC10-14GW PC Notebook
Camera on Rumor 2 Not Working
try other camera apps or try reseting the camera app if both does not work reinstall your phone software
Dec 05, 2017 | LG RUMOR Cellular Phone
Software driver problem
Do any other devices connect successfully to that same USB port?
If no, try another USB port.
If yes, when you reinstalled your software, did you uninstall first? If not, see if you can. Once uninstalled, verify that the device is removed via Device Manager.
Once removed, if on XP or Vista, try to connect using the built in system drivers.
If this does not work, try reinstalling your drivers, but be sure to check for system prompts when you connect. If you do not respond to those prompts, the device will not mount.
Let me know how it turns out.
DigiChick
Nov 05, 2007 | Fuji FinePix A340 Digital Camera
My cam stopped working
may be cheak for loosen or dammege  camera cableand camera also if ok reload the softwere.
Oct 06, 2007 | Sony Ericsson K750i Cellular Phone
Samsung U900 Soul Cellular Phone Logo
55 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
