Door latch broken on hotpoint wt761g washing machine. Machine has gone through wash cycle and emptied all the water, all lights have gone out but I can't open the door.
  • mwilliams858 Nov 20, 2009
    The machine has emptied all the water. The problem is the door handle is very loose as if something has broken. You move the handle and there is no resistance. I wondered whether there might be another way to open the door other than using the handle
    Genius:
  • Washing Mach... Master
  • 1,467 Answers
Depending on which part has gone, some hotpoints door trim post snaps which makes too much play not allowing door to open, in this case needs new door trim. others need drum to be empty of all Water, or could be door interlock faulty .give it a slight bang with your hand to ease open, remember has a 3 min delay on door....
Posted on Nov 20, 2009
  • Gerry Harvey
    Gerry Harvey Nov 20, 2009
    You could try back of spoon , it will open !
Door wont open and F34 error message on our axxis front loader
This error message indicates that you have a Electrical Problem in your washing machine .
Make an attempt
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select RINSE & SPIN, and then select EXTRA
  • RINSE (to turn off the rinse option) if there is
  • excessive water in the washer.
  • Re-select cycle and press START. If the problem
SAM ANDERSON
Sep 27, 2008 | Bosch Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Washing Machines
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
I have a Hotpoint ultima stream washing machine (WMA63) which the light says the cycle has ended but the water will not empty and we cannot open the door, any suggestions??
first to empty the machine--lower the drain hose at the back below the tub into a basin--once all the water is out--wait for about 3 mins and the door will unlock--then check your filter--probably pump prob
Oct 27, 2009 | Washing Machines
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
WF100 door wont open
The interlock has jammed, first try gently pushing the door frame on the latch side of the door and then hit the outer door frame with your fist, not too hard but a reasonable bang this may release the door, if this works spray a lubricant into the latch hole in the panel, open and close the door a few times before reusing, if this fails then you have to force the door open, the best way is to remove the lid and manouver the door lock from the inside, either the lock or the latck will eventually break, this is unavoidable, then replace the interlock and any other broken part.
Regards
Advisor
Nov 17, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA20 First Edition
your bearings have gone and inturn your drum has droped which has cut heater so it has gone 2 earth which is y your electric has triped the whole job should nt cost more than £120 that is what i charge any way 4 a new inner and outer drum supply and fit good luck
Sep 08, 2007 | Hotpoint First Edition WMA20 Front Load...
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
