Question about Sony DAV-S400 System
Display panel says protect as soon as switched on and can get no responce from any command
  • 4,234 Answers
The protect message is an indication that a problem was found at the final stage of the amplifier. Typically, this is caused by defective output transistors. A confirmation of this can be made by removing the speaker wires and turning on the unit. If the protect message still appears, the problem is internal to the unit and it will require repair. The DAV series of units are not the easiest to work on and replacement parts are limited. I would suggest that you get a detailed repair estimate from an authorized Sony service center. Post the results here and we should be able to walk you throught the actual repair.
Dan
Posted on Nov 20, 2009
  • 396 Answers
You have to trail all your wires becasue one of them might be touching start by the reciever check the connections
How Can I Obtain the Serial Number of a Modular Switch?
Obtaining the Chassis Serial Number · On a standalone switch:
Log in to the switch through Telnet or the console interface, and then run the display elabel backplane command in the user view to view electronic label information. In the command output, the BarCode field indicates the chassis serial number.
<Quidway> display elabel backplane
Info: It is executing, please wait...
[BackPlane_1]
/$[ArchivesInfo Version]
/$ArchivesInfoVersion=3.0
[Board Properties]
BoardType=EH02BAKKBarCode=2102113089P0BB000881
Item=02113089
· In a CSS:
Log in to the master switch through Telnet or the console interface, and then run the display elabel backplane chassischassis-id command (chassis-id specifies the CSS ID of a member chassis) in the user view to view electronic label information. In the command output, the BarCode field indicates the serial number of the specified chassis.
<Quidway> display elabel backplane chassis ?
INTEGER<1-2> Chassis ID
<Quidway> display elabel backplane chassis 2
[BackPlane_2]
[Board Properties]
Item=02113549
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the chassis ID according to the help information.
Obtaining the Serial Number of a Card Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a card. In the command output, the BarCode field indicates the serial number of the card.
<Quidway> display elabel ?
<1-1> The present chassis
backplane Backplane
brief Display information briefly
<Quidway> display elabel 1/?
<4,6-8> <CMU1>
<FAN1-FAN2> <PWR1-PWR2>
<Quidway> display elabel 1/6 brief
[Slot_6]
/$[Board Integration Version]
/$BoardIntegrationVersion=3.0
[Main_Board]
[Board Properties]
BoardType=ET1D2S08SX1EBarCode=020LVF6TBB000043
Item=03020LVF
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the slot ID according to the help information.
Obtaining the Serial Number of a Power Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a power module. In the command output, the SN field indicates the serial number of the power module.
backplane Backplane
<5,8,13,16> <CMU1>
<FAN1-FAN5> <PWR1-PWR4>
<Quidway> display elabel 1/PWR1
[Slot_21]
[Main_Board]
DATE=13_02_08 SN=A664A0212080086V0.9A
NOTE:
Obtaining the Serial Number of a Fan Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a fan module. In the command output, the BarCode field indicates the serial number of the fan module.
backplane Backplane
<5,8,13,16> <CMU1>
<Quidway> display elabel 1/FAN2
[Slot_18]
[Main_Board]
[Board Properties]
BoardType=LE02FCMC BarCode=2103010JTF0123456789
Item=02120995
NOTE:
Jul 22, 2016 | Computers & Internet
I have tcl led m. no 24d20 only displays tcl logo and then no responce
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again. Also try bringing up the menu, and see if there's an option "factory default", and try that.
Feb 04, 2016 | Televison & Video
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
Printer unable to clean
This most likely means that the over flow tank is full. You can order a replacement tank but you have to disassemble the printer pretty far to get to it. You would also need to reset the counter so ..... if you want you can just reset the counter. Doing this without replacing the Ink Absorber will mean that once it is truly full it will leak into the printer itself. Do so at your own risk, but then again these are cheap printers....
Brother Maintenance Mode Commands:
- Quickly press Menu/Set * 2 8 6 4 to enter maintenance mode.
- Display should read maintenance.
- Press one or more of the maintenance mode commands below. After each command display should read re-init for a few moments then redisplay maintenance.
- Press 99 to exit the maintenance mode.
Maintenance mode commands:
01 Full RAM clear (see 91 below for retaining user programming)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
99 Exit maintenance mode"
I would use the 01 and reset everything. Otherwise you can go through the 91 parameter list till you find the counter.
Jim
May 11, 2011 | Brother MFC 420CN All-In-One InkJet...
The pen drive indicates write protected and does not allow to write new files.
Three possible sources for this problem, and three separate solutions.
The following procedures assume your flash drive is assigned by MSDOS to drive E:
PROBLEM 1: Pen drive write-protect switch set
SOLUTION: move the tiny switch on the pen drive from the icon of a padlock locked
toward the icon of a padlock unlocked
PROBLEM 2: MSDOS attribute set incorrectly on any/all files on pen drive
HOW TO DISPLAY CURRENT SETTING: START > Run... > cmd
C:\> E:
E:\> attrib /S /D
HOW TO FIX WRITE-PROTECTION PROBLEM: START > Run... > cmd
C:\> E:
E:\> attrib -r /S /D
PROBLEM 3: REGISTRY set incorrectly (targeted by virus or other malware)
HOW TO DISPLAY CURRENT SETTING: START > Run...> cmd
regedit
display HKEY_LOCAL_MACHINE\System\ CurrentControlSet\Control \StorageDevicePolicies
The valid values for this are 0=Disabled (meaning READ/WRITE), and 1=Enabled (READ only)
regedit
set HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\StorageDevicePolicies
to a value of 0 (Disabled)
A fourth way to "Fix" the write-protection problem would be to reFORMAT the flash drive, but
this "solution" merely resets the ATTRIB characteristic of the top-level directory of the
flash drive (while erasing all files on the flash drive), which is done better with the ATTRIB command,
and completely fails to address the possible write-protect switch or Registry issues.
Feb 15, 2011 | Transcend (589307) Media
MY NOKIA 5233 DID NOT GET START? WHEN I PRESS THE SWITCH ON BUTTON IT JUST VIBRATE ONLY THEN NOTHING DISPLAY? ITS NEW MOBILE I BUY IT TWO DAYS AGO.
MY NOKIA 5233 DID NOT GET START? WHEN I PRESS THE SWITCH ON BUTTON IT JUST VIBRATE ONLY THEN NOTHING DISPLAY? ITS THIS PHONE WAS PURCHASED ON 6YRS AGAO.
WHAT I CAN DO NOW.PLS TELL ME
I AM WAITING FOR UR RESPONCE.
MY EMAIL ID WAS:-sureshbheema@yahoo.co.in
so,pls give mail
i am waiting for ur good responce.
regards
sureshbheema
Oct 16, 2010 | Cell Phones
I cant send any messages keeps saying hook uo to
Switch off your broadband connection for ten seconds and try to switch it back on. Go to control panel and click Internet connection as soon as wizard displays. Examine if the settings is enabled. Close the control panel and open run command and type cmd. After typing, when it prompts a command, type ipconfig and see if IP address and provider is listed with gateway and subnet. If it has all the addresses, so you can connect back to GMAIL. Thanks.
Jun 20, 2009 | Google Gmail
I have lost my date and time on display it says "will return soon
Well, either you better hurry up and return soon :-) or go to the phone and dial *7500 on the intercom. There are absent messages in the system that are accessed with *750x commands. You found the first one at *7501
Carl
Mar 17, 2009 | Panasonic KX-T7630 Corded Phone
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
Sony DAV-S400 System Logo
467 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
