Question about Sony Playstation 3 (PS3) Console
System update download error 8002F997 on 3.10 update
  • 7 more comments
  • graybear630 Nov 20, 2009
    the ps3 is working fine but wen 3.10 system update gets to 71% it comes up with error 8002F997
    why would it all of a sudden need to be downloaded different the downloads hav always workd in the past..this sucks big time
    sorry not much help..thanx for your time
    thanx i will try that..
    the other bloke explained it a bit better..im not tryn to be a pain jus cheesed off at why these problems occcur..thank u for ur help..
  • graybear630 Nov 21, 2009
    hey there mate..i tried the flash drive update but now its geting to the same point and saying data is corrupted error 8002F997 at about 71%..i restored the default settings before i done the update but it still wont work..would it be any different on a SD card or would the result probably be the same..this is getting very annoying MW2 is waiting lol..any more help would be great..
  • graybear630 Nov 22, 2009
    hey thanx for your help ive tried the USB download numerous times and still no luck. ive gone to the stage of completely clearing my PS3 of memory. but still not working. if i go buy a new unit what is the chance of this thing happening to it aswell. all i wanna do is play my games online. very annoyed at the moment. thanx again for any help..
    hey thanx for your help. ive tried that so many times but still wont work. i even went out and brought a new PS3 to try and im still getting the same error at the same % of the download WTF!! im well and truly over it..
  • graybear630 Nov 23, 2009
    hey thanx for your time and advice..realy annoyed at the moment even went to the trouble of geting a new PS3 and still the same out come. i tried totally reformatting my old one and it done no difference. now the new one is doing the same error at the same % of download. is this some kind of joke. all my online friends hav had no trouble. if i knew this would happen i would of not even tried down loading the update but as u kno once you go forward u can never go back. thanx for any help!!!
  • 10,515 Answers
As per Sony,
8002F997
Trying to Update the Firmware, copying to a file and installing from a USB drive failed.
As of now, they are yet to release the patch for this Version. You need to wait for few more days before they would release a patch for it.
The only Option you are left with :-
1. Format and check , if that could fix the issue.
2. Back-up the files on your HDD that you want and th format Utility in System Settings. Then try updating.
Unless, Call or Email Sony, so that they must be aware of the same and they would send you a Patch, even though it is not officially announced, if it's Possible.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 23, 2009
  • Sony Master
  • 2,200 Answers
Hi
The fault is not on your end. There are many people complaining that this update is failing to load.The reason for this appears to be that Sony have rolled out version 3.10 within the last few days (November 19 to be precise) and there are more PS3s than their download servers can support.
Therefore the servers are currently overloaded with people trying to update all at once. It is likely that this will self correct and speed up as more people complete the update.
Firmware updates are particularly susceptible to damaged data. If you now have the update on USB - I would suggest that you will first need to format your original PS3 before it will accept the new update. This is due to the possibility that the original failed update has already stored corrupted data. This will prevent the USB update from loading.
Finally to decide whether you really need or want this update in the first place take a look at this and do remember to rate my answer. Thanks.
http://blog.us.playstation.com/2009/11/playstation-3-firmware-v3-10-update/
Posted on Nov 22, 2009
Download from this link below and then put it on a flash drive, memory card, or external hdd. Plug it into the your PS3 and then go to network update then chose the "update via storage media" option. That should work since you are having problems downloading right from your PS3 and should even fix your problems with the new updates.
http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=275&p_created=1184270377&p_sid=GE6cuANj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTU4LDE1OCZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1QUzMgVVBEQVRF&p_li=&p_topview=1
  • 3,741 Answers
Yes it can be sd card problem.try it with another sd card if you have.
the error occurs due to -------- :
8002F997 Trying to Update the Firmware, copying to a file and installing from a USB drive failed”.
to resolve the error:-- copy file back to USB again and try it.you will have to do this till the error does not go.
click this link directly
http://www.ps3blog.net/about/ps3-error-codes/
also try downloading the update from here link
http://www.us.playstation.com/PSN
follow the instructions on that page then put it on a flash drive, memory card, or external hdd. That into the your ps3 then go to network update then chose the "update via storage media" option. That should work if you are having problems downloading from your ps3 and maybe even fix your problems with the new update.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 21, 2009
  • charlymonty Nov 23, 2009
    connect your ps3 at your Friends place where the ps3 is working.and then download the update and check out.so you can confirm is the problem in ps3 or in the operating system where the updates are getting downloaded from the system.
    this will help. thanks keep updated.
  • 643 Answers
Hello, and welcome to Fixya!
Thank you for asking your question here.
That error means, that your ps3 is having difficulties downloading the update.
The way around this issue , is to go to this link.
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html
Download the update yourself to a computer, then save the update file to a flash drive,create a folder named “PS3” on the storage media device. Within the PS3 folder, create a folder named “UPDATE”. < that is where the update file will go..
From the XMB menu, select Settings , then System Update, and then press the X button.
Select [Update via Storage Media], and then press the X button.
Make sure not to turn the power off during the update process, as this could damage the firmware and cause the machine to need to be replaced.
If you have any questions or difficulties please feel free to reply!
Posted on Nov 20, 2009
  • Tre Elkins Nov 20, 2009
    Did transferring the update file via the flash drive help at all?
    One of the many reasons these updates fail, is sometimes when you first try to download the update normally, via the ps3, the network can hiccup basically.. And then at that point, the download gets stuck at the same progress point.
    It can be a playstation server error, an internal machine error , or any other number of small nuances.
    That is why they provide the file as a download in case these error occur.
  • Sony Master
  • 19,396 Answers
Hi.
that happens when an update file is corrupted, or if it cannot be downloaded completely.
If the PS is starting, to complete the update you can try
If the PS is not starting try a reset. You will need to disconnect PS power cord, then to plug it back in, while holding power button down at the same time.
You will hear the console beeping twice, and then the PS will restart and hopefully complete the download.
If that does not work, contact Sony at the number listed on the owners manual.
Regards.
  • 2 more comments
  • Ginko
    Ginko Nov 20, 2009
    Hi.
    Download the update into a memory card, and try updating from there. If that is what you are already doing, then you may need to download the file again.
    Sorry you left bad feedback, now the question will be relocated to a different expert.
    Good luck and goodbye.
    G.
  • Ginko
    Ginko Nov 20, 2009
    Because the download is not complete.
    Goodbye.
  • Ginko
    Ginko Nov 20, 2009
    No much help because you refused all our questions.
    Each time you refuse question gets relocated and experts do not care to follow your problem as you gave already a bad feedback.
    I hope next time you will use fixya in a better way. We have also a free support section in case.
    Goodbye.
  • Ginko
    Ginko Nov 20, 2009
    Ok, no problem. Next time you ask us just wait before refusing. If an expert is not guessing or totally unhelpful, ask clarifications, and answer expert question before refusing, or the service risk to become totally useless.
    Goodbye.
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Xbox360 update download failing
This usually happens when the Xbox does not have enough space to save the update to in order to install it. Make sure you clear out enough space so you are able to properly install the update.
Here is a list of other errors that can happen to system updates.
http://support.xbox.com/en-US/xbox-360/system/software-update-errors
Contact back with the code you get if you cannot fix it using Microsoft's tips and I will try to help.
Apr 08, 2014 | Microsoft Xbox 360 Console
My Buffalo 1TB Ext.Hard drive is not showing on my list of drives on my computer. It shows (in the device manager) an error Code 10..What does this mean?What can I do to fix the problem? Thank you
Almost all Windows operating system users come across system errors at one time or another. A flickering or blank screen, frozen cursor, blue screen, or an unexpected system restart are all indications of a system error. Most of these errors display an error message that you can use to troubleshoot and fix the problem. In this article, we will learn about the code 10 error and then have a look at common causes of system errors and methods to prevent them.
How to Fix a Code 10 Error
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the value FailReasonString in its hardware key, then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
  • Device driver conflicts
  • Corrupt or damaged software files
  • Malfunctioning hardware
  • Corrupt or damaged system registry
  • Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent most system errors. Some of the tasks that you can perform to prevent system errors are listed below:
  • Keep your operating system, device drivers, and software applications updated with the latest hot fixes, security releases, and updates.
  • Run regular antivirus and anti spyware scans to keep your PC free from harmful and disastrous malware. Always keep these software updated with the latest security releases so that your system is always protected against malware infections.
  • Avoid opening attachments of unsolicited emails and visiting dubious websites.
  • Do not download freeware and shareware from websites whose authenticity you aren't sure of.
  • Be very careful while downloading ActiveX controls from various websites. ActiveX controls provide their master with complete control over your system and therefore, a malicious ActiveX control can cause severe damage to your system and may also enable a hacker to steal your personal information.
  • Last but not least, perform regular registry maintenance to ensure that your registry is free from errors. 90% of all system errors are connected to the system registry in one way or another. You can easily perform registry maintenance with the help of a registry cleaner such as RegGenie. This software will provide you with a simple-to-use graphical interface and enable you to scan and clean registry errors in just a few mouse clicks.
System errors are common on Windows systems and can occur due to a number of reasons, including problems with device drivers, hardware, software applications, and the system registry. Code 10 is one such system error that occurs due to problems with a device driver. You can fix this error by updating the faulty device driver. Preventive maintenance with the help of antivirus software, registry cleaners, and a certain amount of vigilance while working on the Internet can help you keep your PC free from system errors.
Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
Dec 17, 2010 | Buffalo Technology 1TB DriveStation...
When i open my files it reads file system error
For the MP610 there's an update available for the system error.
Go to cobyusa.com in internet explorer. Next enter MP610 in the Product Search bar: A list will show up for all support on this player.
Download the firmware update zip file. Unzip the file after download to see the instruction in the pdf file, how to update the MP610.
Jun 17, 2010 | Coby MP-610 MP3 Player
Win32 app error for every application opened. the last thing i downloaded was updates for my hp laptop after stating it had updates available. i can't go to anything , tried accessing control panel to...
Do a system restore. start>all programs>accessories>system tools>system restore.
or in vista: just type system in the start search and click on system restore.
Sep 22, 2009 | Dell Inspiron 1420 Notebook
MICROCODE UPDATE ERROR
Goto http://www.hp.com/#Support
> download drivers and software
> enter pc model number and search
select the os
you will find BIOS Family Processor Microcode Update
click on that link ; you will find the installation instruction and download file
Sep 01, 2009 | HP Compaq d530 SFF PC Desktop
I keep getting this error "Generic host process for win32 services has encountered a problem and needs to close" once I am connected to internet. No issues otherwise. After this error, I have to hard boot...
i had this very error last year
disconnects me from the net every few seconds
the way i fixed it was by downloading the following 2
updates
Update 894391
http://www.microsoft.com/downloads/detai...
and Update 921883
after you have downloaded and installed these manually
reboot ur comp and keep updateing ur computers with windows updates
thats how it worked for me
thanks.
Jun 08, 2009 | Microsoft Windows XP Home Edition
Windows update isnt working
exact error message please so that we can pin down the issue
Jun 15, 2008 | Microsoft Windows XP Home Edition
Sony Playstation 3 (PS3) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
