Question about Medion md40298 Notebook
Laptop was working this moring, switched if off and now it will no work, switches on lights are on but no load up and funny beeping noise
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Nov 20, 2009
  • Medion Master
  • 32,281 Answers
The number of short and long beeps is the POST code error that advises what the fault is and this beep code varies between BIOS manufacturer.
If you get 3 short beeps then the fault could be faulty RAM or the RAM modules just needs re-seating.
Re-seat the RAM modules and if the problem remains, then remove the RAM modules and take them to your friendly computer shop/repairer and get them to test the RAM modules for you.
Faulty warning flashed and beeped, side light and fog lights faulty, but all are working how can I stop this and switch off the warning and bleep noise driving me mad on citroen c3 2006
That is a very rare car these days. I would go to a Citroen forum like this one to ask the question plus find lots of other information.
http://citroenc3owners.com/citroen-c3-help/
May 11, 2014 | Vehicle Parts & Accessories
When switch on laptop,high sound coming
Hi
If your laptop is making a high pitch of noise (long beep) and the laptop is not having any problem booting to windows (operating system) there's a possibility that one of the button is pressed also known as sticky key
Switch off your laptop try to touch and press all the buttons and try to switch it on.
If you will encounter the same thing wait until the laptop boot to windows and open the notepad application and try to use all the buttons
If some of the buttons are not working or some buttons automatically press the problem will be on the keyboard
Is it okay if you will send more information regarding with the high sound coming from your laptop after switching it on because I would be happy to assist you and resolve your question with accurate answer . Thank you : )
Oct 22, 2011 | Samsung RV511A01 Notebook
I was given a Toshiba Satellite. M35X-S149. Celeron M. When turned on I get a beeping noise and the screen is black it never loads up or show the Windows screen. The fan runs a couple of seconds then...
Try reseating the ram modules. If this dosn't work remove them one at a time but keep them in the same slot...do not switch slot, rebooting after each removal. If you remove one and it boots up then ram is bad for that slot. If this doesn't resolve your problem then repost with exactly how many beeps and in what sequence as they are diagbostic codes.
Good luck
If this helps you resolve your problem, please
consider giving me a rating of 4 and maybe a
"thanks" It will help me as well. Thank you.
Dec 03, 2010 | Toshiba Satellite M30X Notebook
Acer Aspire 1800 No Boot. No Power
CONTACT ACER EXPLAIN PROBLEM AND SEE IF THEY CAN RESOLVE THE PROBLEM.HOPE YOU GOT A WARRANTY.
Nov 30, 2009 | Acer Aspire 1800 Notebook
Laptop wont stay on longer than approx 3 seconds. How do I check the switch?
if the switch at least starts the laptop.. then it is not the switch
check that you can boot the pc with the battery pulled out of the laptop and the power supply plugged in...
if this works then you need a new battery
if this does not work.... then the motherboard or the power adapter plug maybe the issue.. is the plug on the side of the laptop solid... or sloppy fitting..
if solid then the motherboard cpu and memory are the suspected components next..
is there beep noises during boot for the three seconds that occur???
Sep 28, 2009 | Compaq Presario X6000 Notebook
My laptop has starting prolem ...when i am switch it on ... it is starting with contineous sound of beep....and also my touch pad mouse is not working some time properly... i had format it two times with...
Hello, hetul58519
I installed some extra memory on my PC, didn't do it quit right and recieved a series of beeps untill I fixed what I had done incorrectly during the install. The beeping is the computer way of telling you something is not right, it is trying to audibally tell you what that is. Now, it is up to you to search for the hidden meaning behind the continuose beep. Do a search for "computer beeps" or "computer audio cues". Do you recieve any warnings other then the beep? Is the computer acting funny in any other way?
Aug 13, 2009 | HP Compaq Presario CQ70-120US Laptop
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Medion md40298 Notebook Logo
216 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
