Question about Lexmark P6350 All-In-One InkJet Printer
Lexmark p6350 error ink catridge not compatible
  • 235 Answers
Are you using a replacement ink cartridge? if youre not using a genuine lexmark ink cartridge and the replacement wont be recognized by the printer it means that the replacement ink cartridge is not supported by the printer
Posted on Nov 20, 2009
How do I make my lexmark p6350 compatible with my toshiba windows 7
Use the Vista driver in Windows 7. Before downloading the printer driver, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download the corresponding driver for your operating system:- Lexmark P6350 Driver for Microsoft Vista 32 bit and Windows 7 32-bit- Lexmark P6350 Driver for Microsoft Vista 32 bit and Windows 7 64-bit
Simply follow the steps on your computer screen to complete the installation.
Feb 27, 2012 | Lexmark P6350 All-In-One InkJet Printer
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Installed refilled ink catriges,both black and color used for a few days all was well then, it reads Catridge Error -Error: 50C Go to users guide. what do I do Now cannot find users guide. plzzz help.
Though Lexmark does not recommend using refilled inks. You may refer to this article from the Lexmark website on Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. If this does not help, try to insert a genuine Lexmark cartridge to determine if your other cartridge is faulty. Thanks.
Feb 24, 2011 | Lexmark X6150 All-In-One InkJet Printer
I cant print and get error message 1203 on my lexmark p315 model:any idea wat that error message is?
t's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Dec 22, 2010 | Office Equipment & Supplies
How can i install lexmark p6350 on windows 7?
Lexmark P6350 printer is compatible with windows 7
(reference link:)
Click on the link below to download the appropriate driver (click on recommended driver after choosing your windows version)
http://support.lexmark.com/index?page=downloadsList&locale=en&productCode=LEXMARK_P6350&segment=DOWNLOAD&os=WINDOWS_VISTA&oslocale=en_US&userlocale=EN_US
Nov 30, 2010 | Lexmark P6350 All-In-One InkJet Printer
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
Error 1203 how do I fix it?
try this solution:
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
Error on my printer - Ink Cartridge not properly installed ...
well, for starters you did install the cartridges correctly. Try turning off the printer then reboot the system, then turn on the printer again. if that doesn't work you should consider buying a new ink cartridge chances are most printer models may not accept refilled ink cartridges.
Hope this helps:)
Oct 18, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Lexmark P6350 and New Imac intel compatibility
I'm part way there.  I rang Lexmark and they say P6350 can only work with Mac OS up to 10.4 whereas I'm using 10.5.2.  I'm not yet fully convinced it can't be made to work and a knowledgeable friend will be round later.  I may get back to you. Porphyry
Feb 22, 2008 | Lexmark P6350 All-In-One InkJet Printer
Lexmark P6350 All-In-One InkJet Printer Logo
281 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
