Question about Sony Ericsson W200i Cellular Phone
My walkman is not working - Sony Ericsson W200i Cellular Phone
My walkman nwz-b152f shows boot error
First, you go to DEVICE MANAGER. Under PORTABLE DEVICE, there is your WALKMAN. Right click on the WALKMAN. Choose UPDATE DRIVER SOFTWARE. Then, LOCATE AND INSTALL DRIVER SOFTWARE MANUALLY. Then, choose LET ME PICK OF DEVICE DRIVERS ON MY COMPUTER. Currently you are using MTP USB DEVICE...so, now choose USB MASS STORAGE DEVICE. Then, click next. Once u have done all this, format your walkman. Your walkman should be fixed. :)
I had the same problem with you before, and i tried this. My walkman has working like usual, now. I'm using Windows 7. So, best of luck!
P/S : U also can change back your driver to MTP once your walkman had fixed by doing the same step. ^^
Feb 11, 2012 | Sony Audio Players & Recorders
Tip
How to Rip DVD's and YouTube Videos(Background music) to Sony Walkman?
Run into fantastic background music on DVD Movies YouTube, MySpace, MSN video, and wanna enjoy the background music on your Sony Walkman? Wanna enjoy DVD movie on Sony Walkman but don’t know how to rip DVD to Walkman? This article will show you how to convert video to Sony Walkman, how to rip DVD to Sony Walkman (NWZ-S618F, 8GB/ NWZ-A818, 8GB/ NWZ-S616F, 4GB/ NWZ-S738F, 8GB) for your watching.
The leading role of this article is Daniusoft Video Converter Suite which is an applied Sony walkman video converter, it is already optimized for output setting for Sony Walkman video (*MPEG-4)/Audio(*MP3) in its profile. Very easy to use, like the follow illustration:
Okay, without further ado, let’s cut to the point to get things work.
First of all, Download Daniusoft Video Converter Suite, after installing it, you will get 2 apps: DVD Ripper and Video Converter.
Next, run Daniusoft DVD Ripper software to convert DVD to Walkman-friendly format: MPEG-4. The nifty walkman DVD converter has all essential functions such output profiles, parameter settings and video editing. The detailed conversion process is showed as below:
1. Click 'Load DVD' button to add the DVD file. You can also click 'Load File' to add DVD/IFO from your hard disk. (Ensure that you have sufficient space on hard drive to store the DVD).
2. Select profile "Sony Walkman -> Walkman Video (*.MP4)".
P.S. If you wanna extract background music from DVDs and convert to Sony walkman, Just Select profile "Convert to -> Common audio -> MP3-MPEG Layer-3 audio(*.MP3)".
3. Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
4. Click "Edit" to adjust effect, length, size and watermark, etc.
5. Click "Start" to convert DVD to Sony Walkman.
Using Daniusoft Video file Converter to extract background songs from YouTube, MySpace, MSN video to Sony Walkman is as easy as Daniusoft DVD Ripper.
1. Run Daniusoft walkman Video Converter and load your video downloaded from YouTube, MySpace, MSN, etc.
2. Select profile "Convert to -> Common Audio -> MP3-MPEG Layer-3 audio (*.MP3)".
P.S. If you wanna convert your favorite web-video files from YouTube, MySpace, Facebook, MSN etc. to Sony walkman, Just Select profile "Sony Walkman -> Walkman Video (*.MP4)".
3.Click "Settings" to customize the parameters like Bit Rate, Video Size and Aspect Ratio.
5. Click "Start" to convert video to Sony Walkman.
Now, you can connect Sony walkman to computer and copy these converted DVD video or background music to your Sony walkman (NWZ-S618F/NWZ-A818/NWZ-S616F/NWZ-S738F) player. Using the Daniusoft walkman video converter well can cover the boring journey on a bus or a plain with myriad happiness and fun.
on Mar 11, 2010 | Cell Phones
My sony media player was conected for computer to chrge now the sony walkman is not working
hi there!
Don't be afraid when your walkman is not working, because maybe there is a defective in your computer that's why your walkman is malfunctioning.
I've already experience your situation right now, and yo know what i did? I just went to a technicians who knows how to fix my walkman. Because there are possibilities that some virus roam in your walkman, and its all because of the computer. But one I am sure that is being infected by the virus from the computer. So before its to late you better go to the technician near your house so fix your valuable walkman. Otherwise, your walkman will be damage.
thats all.... hope you consider my answer to your problem...good luck
Nov 18, 2010 | Sony Walkman NWZ-S616F MP3 Player
The recorder was not used for a while. All functions work well except rewind and cue.
Ho riparato molti d6,d6c e altri walkman di alta gamma, aumentando anche le prestazioni se richiesto e se possibile. La mia email: doctor.walkman@gmail.com I have repaired many D6, D6C Walkman and other walkman high-end, improve your performance if required and, if possible. My email: doctor.walkman @ gmail.com
Oct 03, 2010 | Sony Walkman WM-D6C Personal Cassette...
I bought a walkman S544 and my windows xp wont
*THIS IS FOR WINDOWS XP
First, go to device manager.
*Right click "my computer"
*select "properties"
*select "Hardware" tab
*click on "device manager"
Then find the Walkman device on the list.
(it probably has a yellow "!" on it)
*Right click on "Walkman"
*click "update driver"
*click "advanced" option
*click "next"
*click "don't search I will choose the driver"
*click "next"
*select "USB mass storage device"
*click "next"
Hope that helps. It worked for me. ;)
Nov 15, 2009 | Sony Walkman NWZ-S616F MP3 Player
Can't connect to computer with NWZ-A816 Sony walkman.
I figured it out!
It used to be that when I plugged my walkman into my PC, the screen would read "connecting" but would never actually connect, so I couldn't add/remove songs from the walkman or even recharge it. The solution is easy. Plug your walkman into your PC, and then go to
Control Panel --> Device Manager --> Portable Devices --> Walkman
If you have the same problem as me, the Walkman icon will appear with a yellow exclaimation mark, signifying a problem. Just right click the icon, and selecte "Uninstall". After that, the driver will be removed from the PC. Now, unplug your walkman from the PC, and then re-plug it in, and the driver on the Walkman will automatically upload to the PC, and everything should be back to normal and the Walkman should work perfectly.
The problem is that the Walkman driver in the registry was partially damaged somehow (I think during a registry clean up I did earlier). Just uninstall it, reinstall it by plugging in your walkman to the PC, and voila. Let me know how it works for y'all!
Mike
Mar 25, 2009 | Sony NW-E002BC Walkman MP3 Player
Media Manager for Walkman 1.2 does not recognize Sony NWZ-S615F
look up here: http://www.sony.com.my/support/faq/1169186/product/nwz-e435f/print
Feb 03, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sony walkman NW A3000 20GB
i've posted a solution here.
It was posted for another model, but i think it also works for your walkman
May 23, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Radio not workn
IF YOU NOTICE ON THE TIP THERE ARE BANDS...THOSE BANDS ARE WHAT TRANSFER MUSIC AND SOUNDS...WHEN PLUGGED INTO YOUR WALKMAN, THESE BANDS MIGHT NOT MEET...CONSIDER A NEW PAIR OF HEADPHONES FOR YOUR WALKMAN
Feb 21, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
