Question about ASUS P4S800-MX Motherboard
Well pc fans,hd,cd-dvd works but nothing happends when turned on i just hear it make sound no beeps no diplay and it doesnt turn off i have to turn off with cablle well i went overseas for 3months came bak to use pc and thiss problem if someone could help that would be soo good im soo pised off about it
  • ASUS Master
  • 2,072 Answers
Either the mobo is bad or the power supply is bad or you may have a bad stick of RAM.
You can have CPU fan and lights on and still have a bad power supply as they put out several voltages.
I wold first remove all your RAM and just have 1 stick in. Try this with each stick of RAM by itself I've seen RAM cause this type of problem. Second if you tested the RAM
I would try replacing the power supply they cost about $40 and are easy to replace here is a guide with pictures http://www.hardwaresecrets.com/article/362
If still no go replace the mobo
Let me know if you need more clarification or assistance by leaving comments
Posted on Nov 21, 2009
Beeping sound when starting
Usually when you first turn the power on ... it's usual to hear a couple of beeping sounds . And then, you may hear whirling/clicking sounds when your disk starts up (rotating) and your CD/DVD drive starts up, etc.. Then the monitor/screen lights up and starts to show the operating system (e.g. Windows) panel ... as it starts up.
If your system just beeps ... and beeps ... and beeps... and nothing else happens, the screen doesn't light up and show anything (for a few minutes), it likely the system is not starting up properly.
If you can clarify what actually happens, maybe I can offer more suggestions/information to help.
Apr 03, 2014 | Computers & Internet
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 28, 2012 | Computers & Internet
My 6100 has been overheating a lot lately, so I opened it up and followed ubercam's cleaning instructions. Everything went just fine. I put everything back together, turned it on, and then nothing. It...
my whirlpool awm1203 washing machine wont turn when the timer moves on to the next setting the dial moves then you can hear it click but doesnt turn on
Jan 09, 2011 | Computers & Internet
When I try to power on the PC the green light will flash but nothing else will happen. I thought it might be the power supply but doesn't that usually give a red light and beeps. Neither of the cooling...
Hi take out everything and disconnect all hdd and cd/DVD try turn it on only with procesor, graphic card and memory ( if you got more then one bone try with one if fail try another). You can also try reset CMOS . Let me know what happend
Aug 23, 2010 | HP Compaq d530 SFF PC Desktop
After power on my eMachines C6537, there is no beep sound and nothing shown on screen. The CPU fan and fan in the box are working. The HD drive spin sounds normal. No problem to open doors of DVD and CD...
Disconnect the power cable open the case and pull the CR 2032 battery out for a minute. That will reset the BIOS. If you have no Beep Codes at all the MoBo might be dead. If this were just a video issue there'd be Beep codes. If there's more than one stick of RAM Pull one try to boot then do same with second stick. if there's only one stick of RAM try reseating it.
Jun 27, 2017 | eMachines C6537 PC Desktop
IBM T20 hard disk won't start, no display, and beeping
it may be drive issue,:
- replace the hd and cmos battery,
- change boot device priority in BIOS
to 1st: cd/dvd
2nd: hd
3rd: floppy or network boot or usb-boot
- exit BIOS saving changes: yes
- reboot from windows cd-rom for testing the cd drive
- try booting from new hd (if bios recognizes it,
then install operation system
- if still the same prob, see a technician about this issue
Jun 13, 2009 | IBM ThinkPad T20 Notebook
Pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
dear,
Remove the ram and check, is the motherboard beeps or not..
it should beep as long beeps....and should continue beeping after serveral times until u switch off it...
then reconnect the ram after swiching off power...
remove the data cables of hdd and cd/dvd and then try to switch it on...
if it works fine then reconnect it properly...
Fault can be in Ram or data cables perhaps...
regards,
hope it will fix the issue so dont forget to rate it...
Apr 20, 2009 | Computers & Internet
Computer wont boot, only fan running
check the (memory) ram chip, keyboards, and mouse for faults then try again.
Most time beeps indicate memory errors
Jan 17, 2009 | Lenovo ThinkPad R61i 14 inch widescreen...
Gatweay mx3414 dont start
try removing mem and removing hd check to see if clean re seat them and reboot,
could be bad sectors on hd,but sounds like unit been knocked or dropped and hd not seated properly...
Jan 14, 2009 | Gateway MX3414 Notebook
ASUS P4S800-MX Motherboard Logo
119 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
