Question about Sony Ericsson K800i Cellular Phone
Its just showing a plain white screen. phone wont on k800i
Its just showing a plain white screen. phone wont work.
  • 57 Answers
It could be the LCD sreen, the white screen is the backlight with no data They are very cheap on Ebay about £8 and no soldering is required. Checkout how to take K800i apart on something like YouTubeits just showing a plain white screen. phone wont  - 2_bing.gif. It is only 4 T6 torx screws and 2 philips screws. Take the front cover off and remove and replace the LCD screen and reassembly. Ground yourself, work slowly and you will be fine. Worth a try, if that does not work then you can try the software route but I feel it is more likely to be the hardware. Take your choice and good luck
Posted on Nov 24, 2009
  • Peter Bradley Nov 24, 2009
    Just found out it IS possible to rectify with Wotan Server to repair the EROM which is checked before firmware is flashed. You will have to buy credits and a data cable. Follow instructions pressing key 2 and 5 together. You don't have to but you may as well update the firmware as well after this process. If not it's the screen
This is almost certainly a firmware issue with the phone (Though it could, very rarely, be a fault with the screen or its connection). Reinstalling the firmware on your phone should fix the issue.
By using Wotan Server (http://www.wotanserver.com/en/) I fixed a similar fault on my girlfriend's phone. It didn't work at first, but I charged the handset again and it worked then. It does cost about £6-£7 to use unfortunately (paid up front) but never falsely charged me when it failed.
If you're happy to risk the £7 then I'd definitely try it - better than buying a new handset if it works.
Posted on Nov 23, 2009
  • 55 Answers
Phone needs to be replaced.
Posted on Nov 20, 2009
Flashing white screen
you update and now its not working?????????????
May 07, 2010 | Sony Ericsson K800i Cellular Phone
I turned k800i off now wont turn on!!!!!
just press the switch on/off botton .it will be on
Mar 02, 2010 | Sony Ericsson K800i Cellular Phone
Damaged LCD, Low battery LED on, wont comunicate with PC.
Replace or Repair the display on the Sony K800i. If your k800i screen is cracked, this guide will help you. If your Sony K800i LCD is dead, then this video will show you how to disassemble and replace it. If your lcd screen on your k800i is smashed, then this post will help you fix it yourself for a very low cost.
Replace LCD Screen on Sony K800i Display
Feb 06, 2010 | Sony Ericsson K800i Cellular Phone
Sony ericsson k800i Not turning on
I had a similar issue, whereby my phone would turn on for 30 secs then the screen would go white and the phone would switch it self off then on.
After a lot of messing around even throwing the phone around the place. I took out the memory card and the phone worked fine. When I put the card back in, the phone started misbehaving again, so I guess the card is knackered.
Dec 30, 2008 | Sony Ericsson K800i Cellular Phone
Wont switch on
There is also a possibility of moisture as well. Sony Ericsson's are notorious for going white screen when there is moisture or corrosion in the phone.
To be completely honest regarding Flashing the phone... it is not easy and has many steps. I would recommend going to www.gsmhosting.net. There, search for forums on flashing the K800i software. To flash the phone, you will need a Cruiser Box, the correct cable, and the full software for that phone and your service provider. The K800i is DB2020, which is Sony Ericsson's most up to date encryption.
Believe me though, there is way to much involved in flashing the phone to post here. How long have you had it and if there is no moisture, have you considered a warranty exchange through Sony Ericsson?
Aug 07, 2008 | Sony Ericsson K800i Cellular Phone
White bar coming across my k800i's screen.
try changing the current theme of your phone and check if the white bar will still appear...
May 03, 2008 | Sony Ericsson K800i Cellular Phone
K800i white screen at startup
try removing the memory card and then boot the piece.
Apr 21, 2008 | Sony Ericsson K800i Cellular Phone
My sony k800i got wet can it be fixed
Hello I turned my K800i moble phone off before going to bed, when switching on again in the moring the screen was just a very bright white colour, have not been able to use since, please can you help :O)
Nov 12, 2007 | Sony Ericsson K800i Cellular Phone
Whit screen
Try with the new battery and check it works or not.Otherwise consult hardware vendor for the same.
Son ericsson wont switch on
G'day guys, whats most likely happened is that the there is something wrong with the erom or phone software, I've actually encountered this problem before and fixed it. I listed a set of instructions on my google page: http://trogg07.googlepages.com/
use the search engine to look for the necessary software.
rate me if this has helped you out :).
Nov 02, 2007 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
111 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
