Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Zd 7000 even with the battery or power adaptor the lights on but can not power on the on off switch not working and all the lights on
  • 557 Answers
Dont know why you are trying to shut down with the power button,. But that said. right click the desktop, select properties, go to the screen saver tab, then power. In power go to the advanced tab. There you will have drop downs with options. WHEN it press the power button- shut down - do nothing - hibernate - etc.
Posted on Dec 02, 2009
When I hit the power on button on my compaq nc6220 the yellow battery light flashes and nothing happens
Please try removing the battery, and then connect the power adaptor and try switching the laptop on see it if works if it works then the battery needs to be replaced. I would also recommend if you can check your power adaptor / swap your power adaptor with a know good adaptor (if you have one). The remaining steps will depend on the outcome of the steps above.
Oct 02, 2012 | HP Compaq nc6220 Notebook
HP ZD 7000 wont power up. Will plug in, power light on, press the power button, light goes out computer doesnt turn on
I had a similar though somewhat different problem. My zd7000 was plugged in but it was oscillating between charging the battery and running from the battery. In the past I'd adjust the jack position and life was good - this time nothing mattered. I turned the laptop off and noticed that the charge light came on and stayed on - I guessed something was freaky with the battery so I switched to my spare - the charger light came on, I turned on the power I had a brief power on followed by zzzzttt then everything died. I could smell the stench of electrical burning. I disassemble the whole laptop and removed the motherboard - the back of the power jack is burned. A new jack is $10.
If I had to guess, I"d guess you have a bad jack. I've seen offers to repair this on the net for $100. If the offer is legit, I'd rather pay the bucks - theres only 5 billion screws in the laptop - plus the risk of static discharge damaging to boards or the pain of getting the processor heat sink out without damaging the processor and then getting heat conducting "grease" between the processor and the heat sink when you put it all back together again. I figured my unit was dead anyway, might as well see if I could find the issue. Now I need to get a new jack - and see if I can get it all back together again...
Dec 13, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Problems with hp pavilion zd 7000 lights are blinking but it won't turn on
First check to make sure the power is actually on by seeing whether or not the power button lights up or not. If the light isn't on and you have no power try this.
1. Try a simple power cycle. This will correct the problem most of the time. All you need to do is take out your laptop battery. Connect the power adapter and have your computer off. Hold down the power button for about 1 minute. This is done to clear any static electricity that might be building up. Turn on the power button again and the power should come back on.
Apr 14, 2009 | HP Pavilion zd7000 Notebook
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Loud fans and Shutting down
This Could be a System Processer failure...
Try to Remove everything from the PC, Including Battery or Power surge f you have connected in between te Power socket & PC.
then Try to turn it on.
If the Problem Exists then the comp needs Serviced at the service center.
Jul 17, 2008 | Computers & Internet
Defintely getting power, but not switching on.
There are several possibilities. Let's start with the easiest two. First the battery, take it out and try starting up only with the power supply. Then the memory chips. If a memory chip fails it can cause a no start in IBM's. Take the memory out and try it. Then try it, putting them in one at a time. If these don't work, then I'm afraid your problem lies within. Namingly the power management chip on the motherboard. The pm chip controls the power input, and allows such functions as switching between battery and AC, and battery charging. The pm chip can go without warning, and just because it lights and shows charging doesn't mean this chip hasn't malfunctioned. I've had several IBM's come through my shop that have experienced the same problem you're describing. I've also had them with problems like; it will only power with the battery, won't charge the battery, will charge battery and only run with battery shuts down while charging, only power under AC, etc... all pm chip related issues. Unfortunately, the only solution is motherboard replacement.
Jun 19, 2008 | IBM ThinkPad T40 2373 Notebook
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
187 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
