Question about Akasa Plastic 60mm to 80mm CPU/ Case Fan Adaptor (Clear) Case Cooling Fan, CPU Fan, Fan Kit
Integral ide external HDD reader - blue light wont stop flashing, and wont read all data - any ideas
  • 358 Answers
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Posted on Nov 22, 2009
How to recover data from a broken Western Digital My Book Essential
Remove the HDD inside the case,If the HDD inside is working, remove data with a usb to IDE/SATA Adapter. If the HDD is damaged, which is likely, It ,most likely, can be read, but I don't think you are going to like the bill for that service.
Dec 19, 2012 | Western Digital My Book Essential 1TB...
Hello, my external harddrive (Verbatim, 500GB USB/FW800) stopped working. When connected the blue LED lights up. After 3 sec it goes into flash mode. The HHD makes a clicking sound. The MAC Hard disc...
> the HDD makes a clicking sound.
That's a very bad sign. :-(
> find a way to rescue the [files]
Search online for a professional "data recovery service". For a significant fee,
they can repair your disk-drive, just long-enough to copy your files onto a brand-new disk-drive.
Nov 03, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
My WD external hard drive stopped working
wd external hard drive making ticking noise and seem to have lost all my photos and music
Dec 17, 2009 | Western Digital Computers & Internet
Hard drive goes on blue light go around once pc
Tried to boot the computer in bios. Check if the harddrive is detected in bios. If not detected. Shut down the system,take out the power cable.open the tower and disconnected the hdd IDE cable and connect it to a differnet IDE port. Restart the system and boot in bios check if hdd detected. If still not detected possible issue with hdd. Try connecting on different computer if still issue persist replace Harddrive.
Aug 18, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Copmuter wont start
You can buy a external 2.5inch HDD enclosure which will allow you to remove your HDD from your current laptop put it in the enclosure and hook it up to another computer via usb allowing you to copy the files of the old HDD.
There are also multi purpose devices that allow your to hook up either IDE or SATA drives of 2.5" or 3.5" drives via USB an example of this device is at link. http://techgage.com/article/vantec_sataide_to_usb_adapter/
Mar 18, 2009 | Computers & Internet
It wont start.. what is sata?
You have to make sure first, what is your HDD type? is it IDE or SATA (Serial ATA).
Check it out: http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
You should plug the data cable, to your hard disk. Remember, there's no way to plug your SATA cable to IDE HardDisk because the connector are not the same (I don't know if there's a converter between it).
So, make sure it first. If it IDE, find IDE data Cable, and make sure it plugged to your MainBoard and Hard Disk. Do the same procedure if it is SATA Hard Disk, only this time you should connect the SATA cable from your mainboard to your SATA Hard Disk.
Mar 11, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I turned of my eMac without turning of the 3.5 HDD external enclosure and now the icon does not pop up on my desk top? How do I get the icon back
Boot eMac
Unplug the DATA cable for the external HDD where it enters the computer.
recycle power to external HDD
plug the data cable for the external HDD back into the eMac.
Icon should appear after a small delay.
IF NOT -- Reboot eMac.
Mar 10, 2009 | BYTECC Aluminium 3.5" HDD Smart Drive...
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Simpletech external simple drive model 96300-40001-001--flashing blue light
do you mean that you used this as a "Data" drive and do not have the data stored on your pc...
that is basically the same as having no backup... if it is important, store the data in more than one location.
it is possible that a power surge killed the usb adapter on your storage device.... you may be able to transplant the HDD onto a working adapter or USB->HDD bridge to get your data back
Aug 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
126 people viewed this question
Top Akasa Computers & Internet Experts
David Payne
David Payne
Are you an Akasa Computer and Internet Expert? Answer questions, earn points and help others
