Question about Garden
Show diagram of fuel lines to carb for mac 3200
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello sir, fuel line replacement, for chainsaws. it is very important to use the same fuel line,O.D. & I.D.. you will need about a 1 ft. of each. line with filter to carb inlet. line from carb goes to inlet side of bulb. line from bulb goes to tank. make note where large I.D. line goes to primmer bulb. a new filter would be a good ideal. how i feed new fuel line through fuel tank cut line at a angle grease or oil line feed a little at a time pushing with fingers untail you can grasp with needle nose plires and pull through,it is a time consuming thing there is no other way that i know of. hope this helps, MrFixIt, oh could you please rate this solution, thank you.
    President:
  • 2,220 Answers
There is nothing available to the general public that provides what you ask! If service manuals exist they may not have the detail you seek!
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
I cannot find an IPL for a 3200. Some fuel components, part numbers and a little detail can be found below:
An IPL (Chinese Mac, exploded parts list) can be fond here:
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdf
You may also find the following helpful:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Typical fuel system:
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Nov 20, 2009
2 Suggested Answers
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
Carburetor diagrams
I know of no diagram available for this. But if you have both lines out and visible you can just put them on the carb, fill the tank and prime it and see if fuel moves. If it does your done....if not....flip the lines and try again!
Jul 16, 2014 | Poulan Mvm200vs, Ppb430vs Vs2000bv Blower...
Where the fuel hoses go
If you have a petcock below the tank with a reserve switch, you should have two lines. The smaller one is a vacuum line that goes to the carbs. The other is the fuel line. The vacuum line is important, as without it the petcock will not flow fuel. The presence of a vacuum opens a pneumatically operated valve in the petcock allowing fuel to flow. There should be a nub on the middle of one of the carbs to connect the vacuum line to. The fuel line goes to a fuel rail that feeds all the carbs.
Apr 26, 2014 | 1995 kawasaki ZX-6R Ninja
Do you have a diagram that shows where all the fuel lines on a MAC 2337 string trimmer go? There are two places on the carburetor (Walbro 312) for fuel lines to go, two fuel lines coming out of the fuel...
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Oct 24, 2010 | Garden
I have a McCulloch 3200 chainsaw on which I installed a new primer bulb and fuel lines. The old fuel lines were broken. I figured out which line runs to the carb from the primer bulb but where does the...
From the fuel tank to the carb, from the carb to the primer, from the primer back to the fuel tank. The bulb sucks fuel through the carb excess fuel is returned to the tank. HTH
Lou
Oct 08, 2009 | McCulloch Garden
Aug 23, 2009 | McCulloch Garden
Poulan 2150 type3 / a show me diagran of fuel line hook up from primer bulb to carburator
I have a McCulloch 3200 chainsaw with a cracked primer bulb and all the fuel lines were gone. I cannot locate any information on routing these lines to the carb. I have a new primer bulb and 3/32x3/16" fuel line. Please help me solve this problem.
Aug 16, 2009 | Poulan Garden
McCulloch Chainsaw carb not getting fuel
This is the same problem I have with a Mac 3200. I have: (1) A line from the primer bulb to the front port on the carburator. (2) line from fuel tank, with attached fuel filter, to the other primer bulb port. (3) Line from port on back of carb. to ????. I thought it must be a pulse line, but not certain, and don't know where to run it to. Please let me know when you find out.
Aug 13, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel hose routing problem on a Mac 3200 Chainsaw
This post helped me with my McCulloch Mac 3216 chainsaw. There are two holes in the gas tank - one above the other. One is for the gas line (with the filter on the end) and the other is for the overflow - a simply line that runs from the "out" nipple on the primer bulb into the gas tank. The filtered fuel line goes to the nipple on the back of the carb. Another short line goes from the "in" nipple on the primer bulb to the nipple on the front of the carb.
There are two notches just out from the two holes in the gas tank for holding the lines that go in -- this may help you locate the holes.
I found it helpful to pull the lines that go into the gas tank out through the gas cap hole and leave them hanging out until the housing was reassembled. I also left the lines that plug into the primer bulb hanging out through the hole where the bulb goes until the housing was put back on. Leave plenty of extra line for the lines going out to the primer bulb. Once the housing is in place, cut the lines to the primer bulb and attach them, and slip the lines into the tank, making sure the ends are as far down in the tank as possible. You will need this extra "slack" to work with the housing to get it back on.
May 30, 2009 | McCulloch Garden
Which fuel lines conncets to the carburetor?
Well I finally got my saw running - it occured to me that my older chainsaw never had a primer bulb - so I bypassed it and...pull started it with the choke on till it chugged - then turned the choke off and held the gas full on - pulled the starter cord and was cutting trees - LOL
I did speak with a small engine guy - he explained that the primer is to pressurize the gas tank - so your return line from the carb goes to the suction side of the primer bulb - output to the tank - and pickup line with filter goes to the intake of the carb - FYI - hope it helps ya!!!!!!!!!!
Mar 18, 2009 | Garden
Garden Logo
9,524 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
