Question about Intel Motherboard
Cmos error-defaults loaded failed! - Intel Motherboard
  • 45 Answers
Please follow the following step to correct this error:
1. Change the CMOS battery,
2. Reset the CMOS Settings by using the CMOS Jumpers on the Motherboard.
3. Start the PC, enter BIOS setup.
4. Load the default settings
5. Save, Exit and restart the PC
Thanks
Geodavis
Posted on Nov 20, 2009
Floppy disk fail (40) CMOS Checksum Error Defaults Loaded & Keyboard Unresponsive
Unplug the floppy drive cable from the motherboard and test.
Problem still there??
Check the leads of the 3 integrated circuits starting with the one directly to the right of the LAN connectors, and working down and to the left to the other integrated circuits.
The problem you are looking for is two leads shorted together or a lead broken by somebody who was careless with a card, and hit the IC during assembly.
There can also be a short caused by trash or loose components, but that is not as common.
Oct 06, 2015 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Dell Inspiron 546 MT : replaced cmos battery due to checkpoint error, and now receive a CMOS checksum error and asks to either press F! to run setup or pree F2 to load default values and continue. Wh
Hello there, I am the computer technician that will be assisting you today.
My name is Norman-Wynne Damstra.
Welcome to Fixya, Jbellovary.
Since the battery was removed the CMOS would have Cleared as it needs power from a battery to retain the settings.
This therefore means that the BIOS/CMOS has already been reset to defaults and this is why it is giving you this message.
It sees that the settings have changed and it wants you to tell it why.
When this screen comes up Press F2 to load defaults.
Then let it run.
You will now need to enter the BIOS/CMOS by tapping the delete key on first powering on your computer, until you see the BIOS/CMOS screen.
Now set the date and time and set the Boot priority to HDD, then DVD drive.
Also enable USB2.0 support if it is disabled. Check that your drives are being detected.
Save and exit setup.
It should now be A-Okay.
Take care!
Feb 02, 2012 | Dell Inspiron 546 MT PC Desktop
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Ref GA-81PE1000L Error message on boot up
all the computer bios settings are stored even when the computer is off (like time and fsb)
these are stored due to the help of a cmos battery
when this battery finishes it gives the CMOS Checksum error Default loaded error
all you need to do is replace the cmos cell
it is a mercury cell (looks like a silver coin) and will be placed on your motherboard
it is very very cheap so go buy one and replace it and be happy
Sep 30, 2009 | Intel Motherboard
Boots to 'CMOSS checksum error'
CMOS checksum errors
Explanation: A checksum is computed as an error-detecting code, to protect the BIOSsettings stored in the CMOS memory.Each time the system is booted this number is recomputed and checked against the storedvalue. If they do not match, an error message is generated to tell you that the CMOSmemory contents may have been corrupted and therefore some settings may be wrong. BIOSesreact in different ways to encountering this sort of error. Some will warn the user andthen continue on with whatever settings were in the CMOS. Others will assume that thesettings that were in the CMOS were corrupted and will load default values stored in theBIOS chip "for safety reasons". The error message will indicate which yoursystem is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that islosing power. Viruses can also affect CMOS settings, and motherboard problems can alsoaffect the stored values.
You should make sure that all of theBIOS settings in the system are correct, by rebooting the system, going into BIOS setupand double-checking all the values (hopefully against a recent BIOS settings backup).
If you have created a backupcopy of your CMOS settings then use them to restore the settings to the correctvalues. To find the problem itself:
Apr 06, 2009 | Intel Motherboard
CMOS Error
hi
2 things, first, you simply need to replace the cmos coin cell battery or worst case scenario, your processor may already be on its way to failing.
Oct 15, 2008 | Intel Pentium 4 505J Prescott 533MHz...
OVERCLOCKING FAIL/CPU FAN ERROR
First approach shold be the CMOS utility, check in FAILSAFE DEFAULTS that the error settings for shutdown are either null for overclocking or disabled if you don't have the failsafe defaults on your CMOS utility then set your settings to best performance (should be found on the main page of the CMOS utility). If you are unsure of touching the CMOs then you could try to remove the CMOS battery (small 3 volt battery about the size of a 20 cent coin) located on the motherboard this should reset the CMOS and fix the problem. hope i could help,thanks:)
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
Intel Motherboard Logo
137 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
