Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Blue grid popping up and filling the screen
I am getting a blue grid popping up. It is full screen and only lasts a few seconds. On one occurance it remained on the screen and I had to power the unit off. The program is still viewable behind the grid. I have a DVR so I reversed the program and reran the portion where the grid popped up and it wasn't there so it has to be the TV.
  • 58 Answers
You have a defective light engine. Here's what you can do..we just went through this about 2 months ago. Call Hitachis custimer RELATIONS department at 800-654-7013 and tell them you have a defective light engine. When you initially call, they will act like they've never heard of this problem but they have. They will give you the name of some certified Hitachi Dealers in your area. Once you call a tech to come out and confirm that it's a bad light engine, call Hitachis customer relations department back and they will call the dealer directly to confirm the problem. Once the problem has been confirmed by the dealer, Hitachi will send the part directly to the dealer to come out and install.
Now here's the deal. Hitachi will repalce the part (cost around $1500) but they will ask you to cover the install. Our install was $400 but others on this board have paid less (range $200-$500). If your set is still under warranty, Hitachi will pay for the install and the part but regardless if your set is under warranty or not, they ARE paying for a brand new light engine.
A couple of quick things to look out for, please do not let any dealer or store tell you that you have to pay for this part. Hitachi is covering the cost. They have not recalled this part but they are replacing it after you have a tech out to confirm the problem. Also, only deal with the CUSTOMER RELATIONS department and not Hitachis customer service department. The regular customer relations department is no help at all. Good Luck:)
Posted on Jan 14, 2008
How to remove grid
The blue button is not for magic focus on this model----the front grill beneath the screen can be removed and behind it is an inspection plate---the tiny blue button is at the front and to the left and with set on and it pressed the set will enter the decam mode----a grid of lines will show and then buttons on the original remote do different things to adjust convergence and then save the adjustments.
I convergence is way off don't try to adjust it as it will only make matters worse---usually the two chips need to be replaced and sometimes a resistor as well.
Nov 03, 2012 | Televison & Video
When I switch my tv to the HDMI input it appears to be normal for a few seconds but the screen stays black and I get a thin pink line running horizontally across the bottom right corner of the screen then...
You did not mention what you are connecting with HDMI but I have had problems with my PS3 and it is copy protection related. On a PS3, you have to connect it to HDMI1 otherwise some BlurRay movies will not play.
You might have a bad HDMI cable. I have heard the quality of cable does not matter these days but I still have had issues with the really cheap cables. I still do not buy the really expensive HDMI cables though.
Aug 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
3 screen colors have separated and screen is bowed in the middle.
I take it this is a projection TV. so they use three lensed CRTs red green and blue. you should have a setup screen that projects a grid pattern. red green and blue. there is SOMEWHERE a adjustment that overlaps the three projected grid patterns. Making a WHITE single grid pattern. red green and blue make white light. Pin cushioning is the bowing. you may find a POT to adjust on the back of the set. I have no idea what set you have.
Lastly.. Pin cushioning can also be caused by faulty flyback transformers.
Hope I could help.. new here LOL
Happy Fixing =)
Jul 12, 2009 | Televison & Video
Normal pictures fades to blue screen within 30 seconds
The fix for this is here somewhere, as I had the same problem last January and the solution was posted here in March last year. I'll try to find it and post the link to it for you, later.
Nov 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence issues
Drifty convergence IC's need replacing..located on center PC board......STK392-570...change them both for reliability...T.
Feb 28, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence problem
I have a hdtv my red and blue are offset i need to know how to adjust properly
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection turns blue
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
59 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
