Question about Plantronics Telephones Supra
TV is stuck in HEAT RUN mode - Plantronics Telephones Supra
Why is my Duo Therm Heat Pump Running in Aux Heat Mode?
If the compressor is running in heat mode but not producing any heat then the change over valve may be stuck. That is a job for a pro. If the thermostat isn't applying power to the changeover valve then a thermostat change is easy to do.
Aug 18, 2014 | Heating & Cooling
Reverse valve dont work
You may have a bad thermostat, Bad coil on the reversing valve or stuck valve. If you have the ability to safely measure the voltage; then you can check for 24vac at the valve while your thermostat is set for cool. the unit does not have to run. Now if your issue is that it will not heat in heat pump mode but will cool then most likely your valve is stuck.
Jan 16, 2013 | Goodman Heating & Cooling
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
Can't seem to get the compressor to come on. When
hi how are you...you say your outdoor unit is not working...is thermostst set in heat or cool when this is happening....if the compressor is running,go outside put your hand on the big copper line,if it is hot,your in heat mode,if it is cold your in cool mode..is it heatpump or ac only...if ac only ,you have a sequencer stuck ,or contactor closed keeping heat on...please chek items first...michael doctor airr appl.repair 843-384-8474...if need help call,ill help talk you diagnosis of problem...
Mar 27, 2010 | Carrier 38CKC060 Air Conditioner
Heat setting wont run on auto,its stuck in the economy mode
Whenever there is a measured loss of freon, compressor switch will blow and will remain on "ECON" till repaired and the computer is cleared
Mar 14, 2009 | 1996 Cadillac DeVille
Heat pump fan does not run when house heat is on
The outside fan should be running except when the Heatpump goes in to defrost mode. Then the fan stops with the compressor running and it switches the reversing valve to heat up the outdoor coil. That should last about 5 min and you may see steam come off of the outdoor coil. That's normal.
Is the compressor running? It's possible that it's stuck in defrost or the fan simply died. I hope this helps.
Feb 19, 2009 | Sharp CV-P09FX Air Conditioner
1999 ford expedition,interior heat not working properly
have you checked the thernostat. sometimes it gets stuck in the open position and that will make your car run cool
Dec 08, 2008 | 2000 Ford Expedition
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
Can't get my zenith TV off Video mode
not sure what year this tv is, but I had some where the tuner was bad and would be stuck on video. The only way is replacing the tuner. Or you may want to try hooking up a vcr into the video audio jacks and run the channels from the vcr it may work yet.
Oct 03, 2007 | Zenith SY1931SG TV
Lands Phones Logo
87 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
