Question about Olevia LT26HVX 26 in. LCD Television
Lcd tv picture problem
I have a Olevia LCD HDTV, 26" a little over 2 years old and out of warranty of course. When you first turn it on it's perfect, but after it's been on for 30 minutes or so it gets a horizontal thin black line a few inches down from the top. I'm sure this is nothing I can fix, but was really wondering if any one knew if it was fixable by a repair shop and whether it was going to be an expensive fix. Thanks.
  • 1 more comment
  • Anonymous Apr 25, 2008
    I have a Olevia 26 in. HDTV ready LCD, about 2 years old. Color is screwd up (Screen is not displaying the colors it should have -- seems like colors are inverted: read becomes blue, yellow becomes redish purple ... and the color adjustments cannot be used (doesn't change as you press the buttons).
    Poor technical support. I am not going to buy Olevia again. It is a Taiwan-made TV, isn't it?
  • muhammad_glo Mar 17, 2009
    we have the same problem did you get any ans sound and no picture black screen
  • Anonymous Apr 25, 2009
    My 2-year-old Olevia 542i 42" also has the same problem: It has TV/DVD/game sound, but no pictures!
    Menu contrls, info displays, etc are good.
    Any idea? Thanks!
I had my tv working for like 30 mins then i turned it off then it don't turn on if u know how to fix this plz help me
Posted on Feb 25, 2012
Sometimes when i first turn on my tv i get sound but no picture why does it do that? its a 42 inch 542i
Posted on May 16, 2008
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
Posted on Jan 18, 2008
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
Turns on to olevia screen but then just flashes the olevia logo
Just check the input connection. Check it connected with external antenna. Check its input selection. Refer the user manual for details.
Feb 26, 2013 | Olevia 26" 226-t11 hdtv widescreen lcd tv...
26" Sanyo HDTV LCD Model
board burnt out where can i purchase a new one
Apr 02, 2011 | Sanyo DP26649 26 in. TV
Olevia 32 inch tv turns itself off after a min everytime i turn it on its 4 years old? what do i do
Aside from trying different power cords, I'm afraid there isn't much you can do with an LCD TV with a power issue. Since it's four years old, I'm assuming it's no long under warranty. Did you purchase it with an extended coverage plan or anything?
Sorry to be the bearer of bad news. Hope it helps, though!
-Kevin
Jan 04, 2011 | Olevia LT32HVE 32 in. LCD Television
Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Apr 27, 2010 | Olevia LT37HVS 37 in. LCD HDTV
L have an olevia flat screen tv that turns off on its own whenever... what could it be?
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Apr 04, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Feb 21, 2010 | Olevia LT27HVX 27 in. LCD Television
Olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Vertical line of dead pixles on Olevia 237T LCD HDTV
Replace the screen. It is faulty and is covered by your extended warranty. Any problems, contact your Trading Standards Office.
Mar 20, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Open Questions:
Olevia LT26HVX 26 in. LCD Television Logo
709 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
