Question about Dell PowerEdge 1800 Server
Hello, my dell poweredge 1800 does not see up than 256MB RAM, how I can fix it? I have 1GB RAM on the board...
  • 3 Answers
Depending on the RAM you have installed, there could be a bad chip on the RAM module. Standard Memory is sequential and will stop once it reaches a bad chip. To test this rotate your RAM mpodules by moving the first module to the last bank. If the memory increases then you have a bad module.
Posted on Jul 22, 2014
  • 110 Answers
Check the RAM frequency of the RAM which should be compatible to the main board. also chk for the other RAM frequency also
Posted on Nov 20, 2009
My dell poweredge 1800 doesnot boot, it gives an amber light after turning on . I have tried to remove the Ram but still the problem persists
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.May also be caused by a defective card installed in the motherboard, i.e. video card.
Jan 31, 2012 | Dell PowerEdge 1800 Server
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
There is 1 gb ram in my dell poweredge server but showing only 256mb. So how to enable the ram from bios
i think you might have not fixed the ram properly. try to refix or replace it with other and check it.
Nov 18, 2009 | Dell PowerEdge 1800 Server
Physical Memory is limited to 256 MB" in dell 2600 poweredge
In the bios there is an option to install OS, make sure this is flaged as off, when you reboot you will have access to the full amount of onboard ram.
Aug 20, 2009 | Dell PowerEdge 2600 Server
Blue light flashing
Someone has pushed the system identification button on the front of the server. If you push it again the light will be solid blue.
Dec 24, 2008 | Dell PowerEdge 1800 Server
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
Available memory limited to 256
Turn off the option n the bios where it says OS Installed make sure it says os not installed
The Bios will only use 256 ram
Sep 04, 2008 | Dell PowerEdge 1800 Server
Dell PowerEdge 840
reinstall your server it will resolve your porb.
Dec 03, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 1800 Server Logo
559 people viewed this question
Alun Cox
