Question about HP OfficeJet 9120 All-In-One InkJet Printer
Unable to print on HP officejet 9120. Error ; Load A4 in tray 2, Plain paper. Tray is empty or media type/ size in tray is incorrect. Ensure media in tray matches printer driver or control panel setting.
    President:
  • HP Master
  • 2,022 Answers
When you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
Posted on Nov 20, 2009
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
How do I change tray settings from tray 1 to tray 2?
Browse through the menu's of the printer
Paper Handling Menu, Set
Tray 1: Any size / Any Type.
Tray 2: A4 Size / Plain Type.
This should solve the issue
Regards,
Nikhil
Jul 10, 2009 | HP LaserJet 2420 Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
Nov 30, 2007 | HP LaserJet 4350 Printer
HP OfficeJet 9120 All-In-One InkJet Printer Logo
284 people viewed this question
Seeker5211
Seeker5211
