Question about HP OfficeJet K7100 Photo inkJet Printer
Can not print when the print star it load out of paper but the paper is fiil in the printer
    President:
  • HP Master
  • 2,022 Answers
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Posted on Nov 20, 2009
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
Trying to print a picture from the web on XP-810 epson on regular 8x11paper, printer tells me load paper on cassette 1 but cassette 1 only takes picture size not 8 x11. Cassette 2 is where the 8 x11 i
I Just right click on picture select save as. I now have a copy in my pictures. right click on picture select print, on the drop down window select paper size A 4 is 8X11 if it asks print to paper size click ok.
Oct 02, 2014 | Office Equipment & Supplies
Why does my star sp700 printer only print in red ?
seriously people? he said it's printing red. obviously it's not out of paper, the door is not open, there's no paper jam, etc.
Apr 27, 2013 | Star Micronics SP700 Receipt Printer
When I send something to print the right hand side of the paper comes out all crumpled up, as if there is something stuck that it can not pass. I have looked in the printer but can't see anything. When...
Issue
While printing, the printer paper is torn, ripped, wrinkled, or damaged.Solution Follow these steps in the order presented to resolve the issue.Step one: Remove all paper from the input and output trays Remove all paper from the input and output trays on the product.Step Two: Check the paper path for obstructions Press the Power ( ) button to turn off the product. Verify the input tray is empty, and then check for paper jams, bits of paper, and other obstructions, gently removing any obstructions.Lift the top door or the front cover, depending on the product, to access the print carriage, and then check for any obstructions in the paper path.Gently remove any paper or other obstructions from the paper path you might find, and then close the print carriage access door.Open the rear access door.Gently remove any paper or other obstructions from the paper path.Check the spring-loaded rear access door rollers to verify that they are clean and can be rolled.check the paper rollers inside the rear access and verify that the rollers are clean and roll upwards.Check the star wheel assembly inside the printer on the output side of the carriage. Verify that it is in good condition and clear of paper bits or other obstructions. NOTE:The star wheel assembly is located inside the printer on the output side of the carriage. The star wheel assembly is a set of small, star-shaped wheels on top and rubber rollers on the bottom. The assembly grips the printed side of the paper, and moves the paper to the output tray after printing.Replace the rear access door and verify that the rollers on the door and the rollers inside the rear access of the product are "matched up" with each other.Press the power button to turn on the product.Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include: Plain paper, 20 to 24 lb (75 to 90 gsm) Legal size paper, 20 to 24 lb (75 to 90 gsm) Card stock, up to a maximum of 110 lb (200 gsm) Envelopes, 20 to 24 lb (75 to 90 gsm) Photo paper, 145 lb (236 gsm) NOTE:Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.Step Four: Make sure that the paper is loaded correctly Gather a stack of plain, white paper and load it in the product's input tray.Use only one type of paper in the stack.Use 10 to 25 sheets of paper in the stack.Fan the stack of paper to make sure that the sheets do not stick together. Tap the stack of paper against a hard, flat surface, such as a table top, to make the edges even.Insert the stack of paper into the input tray.make sure that the stack of paper is flat in the input tray. Verify the right side of the stack of paper touches the right side of the input tray and that the stack is pushed completely into the tray.Position the paper guides firmly against the sides of the paper stack without bending the paper.Step Five: Test the All-in-One Follow these steps to print a self-test page. If the page prints successfully, the product is functioning correctly.Press the Setup button on the printer.Depending on what product you have, perform one of the following:Press the arrow key to select Print Report and then press OK.Press the arrow key to select Self Test eport and press OK.A test page prints.If the test page prints without damaging the paper, you do not need to take any other action.If the test page is damaged during printing, proceed to the next step.NOTE:For printers which do not have a Setup button, check the product documentation to find out how to print a self test page.Step Six: Contact HP If you have completed all the steps listed above and are still experiencing a problem, the rear access door or the star wheel assembly is likely damaged. To replace the rear access door, contact HP. If the star wheel assembly is damaged, replace the product.Cause There are several possible causes: Bits of paper might be obstructing the paper path and need to be cleared.Unsupported paper types and sizes might catch and tear in the printer mechanism while printing.Paper pushed too far into the input tray when it is loaded, might feed into the printer incorrectly, causing the paper to tear.Paper stacks loaded into the input tray with too many or too few sheets of paper, might feed into the printer incorrectly, causing the paper to tear.Paper stacks that are not properly stacked when loaded into the input tray, might feed into the printer incorrectly, causing the paper to tear.The rollers on the rear access door and inside the product's rear access might not be clean, in good condition or freely rolling.the star wheel assembly might be obstructed or have damaged or missing parts, causing the paper to tear.The rear access door might be damaged.The wheels on the star wheel assembly might be damaged.
Oct 12, 2011 | HP Officejet J5780 All-In-One InkJet...
He printer goes to print but the page comes out blank
Hi
Please load the paper correctly with the side that can be scored by your finger nail pointing downwards.
Contact support@star-emea.com for further help.
Star Support
Aug 19, 2011 | Star Micronics TSP600 Thermal Printer
The printer just keeps printing an incripted code, then feeding blank paper & starting over again until it's out of paper. We have to turn it off in order not to use up all the receipt paper.
Hi Star Customer
Please make sure the printer is configured to use ESC/POS by opening the printer software and select ESC/POS mode.
Please contact support@star-emea.com for more information.
Star Technical Support.
Jul 26, 2011 | Star Micronics TSP100 Thermal Printer
I changed paper and now it wont print just spits paper out
Hi
Please turn the roll over. You should now see print out.
Jun 21, 2011 | Star Micronics TSP100 Thermal Printer
The star tsp700II receipt printer I have was working great and then one day it started feeding paper before each receipt. So it wastes about 6inches of paper on every receipt. I cannot figure out what...
Our Star TSP700II leaves about 1/4 inch of unused paper on the roll when the error light comes on and the printer stops printing. Is there any way we can make an adjustment so that we're not wasting so much paper?
Oct 22, 2010 | Star Manufacturing Star TSP700 Receipt...
My star sp200 will not print when asked. The "online" light is not lit up (I'm not sure if it was on before the problem) When I unplug the printer port cord, the online light comes on and the feed button...
1. check the usb or parallel cord to the PC to see if it is connected proper ly
2. clear all print document on the pc
3. If the "online" light will not come on this may mean that the cord is not completely in the connection socket.
4. check Dip switch for parallel cable ( should be 3 ON, 4 ON, 5 ON) this is for USA settings
5. check paper roll ( if at the end of roll it will shut down if proper paper load is loaded.
6. When temperature at the print head is high printer will go "offline"
7. check the alignment of the ribbon also
Mar 18, 2010 | Matrix Star SP200 Receipt Printer
R1800 wheel marks on print
you can try to load your paper by the back of the printer. This problem problably arrived wen you taste a new heavy paper (too heavy?)
Jan 23, 2009 | Epson Stylus Photo R1800 InkJet Printer
HP OfficeJet K7100 Photo inkJet Printer Logo
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
