Question about Nokia N95 Cellular Phone
Hi please can you tell me how to turn dtmf tones on on my n95 thanks
  • 945 Answers
Http://www.phonedog.com/cell-phone-research/nokia-n95_user-manual.aspx
After 45 mins i`ve found your manual.it looks like you have to incorporate the tones in the profileof your settings of whose calling.
So you should be able to set the keypad to be mute ofr dtmf.
Fingers crossed !
Posted on Nov 20, 2009
NET10 W408g does not allow using the Xlink gateway fully, especially sending DTMF codes to automated systems.
Jim
Been a long time since I have seen this phone but I seem to remember a setting like this. Some phones had a long and short setting too.
Mark
Motorola Support
Activate DTMF tones: Menu > Settings > Initial Setup > DTMF When you dial a number, your phone sends it to your network as Dual Tone Multi Frequency (DTMF) tones. To send DTMF tones during a call, just press number keys or scroll to a number in the phonebook or recent calls lists and press Options > Send Tones
Dec 17, 2012 | Motorola Mobility W408g - Silver net10...
Where can I turn on the DTMF setting on my LG800G phone?
On the Net10 and Tracfone LG800G the setting for the DTMF isn't located under settings, one of the quirks with this phone. You have to make a call using the number/keypad and when the call connects use the menu key on the bottom left (after unlocking the screen) to bring up the in-call menu and the DTMF On/Off settings are located there. Not where you would expect them to be!
Jan 07, 2012 | LG Cell Phones
What is principle behind pulse dialling mode & tone dialling mode in technical terms
Pulse dialing is a holdover from Rotary phones, which when the rotor is turned and let go, counts out the number you entered in clicks on the telephone line. Pulse, or DTMF (Dual-tone multi-frequency), uses two overlaid tones (one for row and one for column) to signify a button press.
DTMF frequencies:
http://en.wikipedia.org/wiki/Telephone_keypad
Mar 19, 2011 | Cell Phones
I cannot delete voice messages after having heard them. The dialpad does not recognize the touch to keys. How do I reset?
I HAD THE SAME PROBLEM, THIS FIXED IT. I HAD TO TURN THE DTMF TONES ON.
Goal:
Enable or Disable Touch Tones (DTMF) for the LG Xenon (GR500) Fix:
LG Xenon (GR500) Keypad Layout
Enable or Disable DTMF tones
  1. From the standby screen, tap the menu icon.
  2. Tap the settings icon.
  3. Tap Call.
  4. Tap On or Off.
Feb 27, 2010 | LG Xenon GR500 Cell Phone
Accessing Voicemail on LG KS360?
When you press numbers do they appear on screen as if you had pressed?
Is it that when you press a key your voicemail just does not respond to the option number you pressed?
If the answer is yes to these it sounds like you have turned off DTMF tones. If it is off, key presses look like they work but actually the phone is blocking the tone for that button from being sent down your line. People sometimes turn off by mistake or to stop their mobile number being visible when calling someone. If you look in menu and make sure DTMF tones are ON it should solve your problem? Hope that helps?
Apr 26, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
ID 27831F32
DTMF is techno-speak for tone dialing (as opposed to pulse). Your GE phone is DTMF.
Nov 20, 2008 | GE 27831FE2 Phone
Keypad tones
Hi, the DTMF tones are controlled by Program 35, LED 17on a per port basis. This is the Station Class of Service program and should be changed by someone with programming experence
Oct 14, 2008 | Toshiba DKT2010SD Phone
SF-515 does not dial anymore
Hi there try this press menu then using the arrow keys go into machine settings I think if not you are looking for line type. Once in the make sure it is set to tone.
Once you have done this come out and try if this doesn't work then the control panel maybe faulty and you could take it apart and clean the number pad keys and make sure that the buttons move freely.
If they do cleanup and put back together and check machine if it still doesn't work then the panel will more than likely need replacing.
Thanks J
Nov 14, 2007 | Samsung SF-515 Plain Paper Laser Fax
Can't get to voicemail
Change the DTMF found in phone settings (Initial Set-up) to either short or long. When this is set to off, the voicemail cannot pick up the numbers you type.
Oct 25, 2006 | Motorola Mobility RAZR V3
Nokia N95 Cellular Phone Logo
190 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
