Question about Seagate (ST3500601CB-RK) (ST3400601CBRK) 400 GB Hard Drive
Please i need the power adapter rating for seagate
Please i need the power adapter rating (input/output voltage and ampere) for seagate 400GB external hard drive
  • Seagate Master
  • 32,281 Answers
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Posted on Nov 20, 2009
Seagate external hard drive usb and power adaptor
any power adaptor would do it as long as the voltage is good (usually 12v) and amperes is the same or higher than what's written in your hard drive enclosure (usually 1Ampere = 1000mA) is good enough, some HDDs use up to 2000mA
Usb cable is very easy to find
you can find those at any electronic parts selling or ebay
Please rate
Jul 18, 2013 | Computers & Internet
Lost power supply for Seagate 3.5 external drive
You can use it, just make sure that the polarities are the same as the original.
Apr 07, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Can i use AC Adaptor that has input: 230V-50Hz output: 9VDC to Creative SBS 2.1 370 Speaker?
The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
Nov 02, 2011 | Creative Labs SBS 370 Computer Speakers
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
When the power charger is on my compaq nx6310, it run very slow, but when I use it without the power charger, only battery, it runs well... it works good!!! My S.O. is Windows XP professional sp3 I use...
You need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 19, 2010 | HP Compaq nx6310 Notebook
I need the size or model number for a replacement charger for the gateway solo 9550.
Compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Aug 30, 2010 | Gateway Solo 9550 Notebook
Power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Oct 16, 2007 | Seagate 400GB 7200rpm External HDD Retail...
Seagate (ST3500601CB-RK) (ST3400601CBRK) 400 GB Hard Drive Logo
380 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
