My pc doesn't start - Office Equipment & Supplies
  • 1 more comment
  • mstrweb09 Nov 20, 2009
    I see the boot display, but then the process goes in a standing-off situation...
    How can I install hard disk on different computer or enclosure to recover files?
    How can I reinstalling Windows?
    Thanks!
    Please, could you give me more assistance? Thanks!
    yes, there are lights. It's a desktop pc.
    I try to power on the pc, but after few seconds of normality it goes in switch off, with power on, but without any "sign of life"... How could be?
    Thanks!
  • 13,433 Answers
Do you get any power lights on the computer? is it a laptop or a desktop? what happens?
Posted on Nov 20, 2009
  • Ekse Nov 20, 2009
    Hi
    It sounds like the contents of the drive are corrupt, all the steps and solutions to solve this issue are somewhat advanced, and you might have trouble in following with them, I would recommend that you take the machine to a friend who knows how to fix the issue or to a local pc repairer.
    or if you wish to attempt to fix this yourself and you feel confident that you can do it then I can advice you further.
    Do you have another computer that you can use?
    Well if you have a windows installation cd, then you could follow these steps to perform a repair installation of windows, note - if you have a recovery cd, it most likely will delete your files. So only do this with a windows disc.
    this is for xp, but its similar on 2000 and on vista.
    insert your Windows XP Setup CD, and restart your computer.
    1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
    if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu, it will very likely be button F12 or similar, it should say on the screen when you power on.
    if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
    after that you should be able to start from the cd.
    here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change...
    Repeat step 1 when you have changed the boot order.
    2. Now you should have a blue screen with text - Press ENTER when you see the message To setup Windows XP now.
    3.Do not choose the option to press R to use the Recovery Console.
    4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
    5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
    6.Follow the instructions on the screen to complete Setup. Do not start from the cd again, when the computer restarts let it start on its own, don't start the cd when asked.
    7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acerhttp://support.acer-euro.com/drivers/dow... for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
  • 19,396 Answers
Hi.
The first thing to do is always unplugging computer power cord for ten minutes. This will reset the computer and can fix minor problems on any of the circumstances listed. If the computer is a laptop, also remove battery while power is not connected, so to drain power completely.
I am listing below all possibilities, followed by brief description of fix needed.
If the computer is completely off, and no light or sound is coming from the computer when you try turning it on, then you may have a blown power supply unit.
- Have PSU tested and replaced.
If when you push start button, the computer turns on, you hear the fans coming and see lights, but there is no display at all, then you may have a problem with an hardware component, commonly motherboard or video adapter.
- Start main board with minimal set of devices. Have hardware tested and repaired.
If you can see the initial boot up display, and then you get Operative System not found or No Hard Drive, then either the disk is damaged, or Windows installation is corrupted.
- Install hard disk on different computer or enclosure to recover files. Try reinstalling Windows. Replace hard drive.
If Windows start but then freezes , then windows files needed for startup had been damaged (eg. Startup.ini).
- Start in safe mode by pressing F8 on startup, if the PC is starting, then do a system restore to a date when computer was starting.
Attempt system recovery using windows install disk.
Reinstall Windows.
If you want more detail on any of the operations listed above, just let me know.
Do not forget to leave feedback.
Regards.
  • Ginko
    Ginko Nov 20, 2009
    Hi.
    Before removing the hard disk try reinstalling Windows or recovering the system.
    To do this you will need a Windows setup disk.
    Before reinstalling Windows try also starting the computer in safe mode.
    The computer is started in safe mode by pressing f8 on startup.
    If computer is starting in safe mode, do a system restore to a date before having the problem.
    If computer does not even start, try doing a new Windows installation.
    To install Windows you will have to start the computer with a bootable Windows CD inside.
    When asked choose Boot from CD and follow instructions.
    You will need to enter a valid windows license number when required.
    When you get asked to choose the kind of installation, try first selecting Upgrade Setup. This will preserve most settings and all your data.
    If the Upgrade setup option is not given, then choose to install the system into a different folder. In this way the data from previous account won't be deleted.
    If the installation is prompting you that there is no disk inside the computer, then the disk may be faulty and all data lost.
    If you want to recover data you may try buying an hard disk enclosure, like this ones :
    Shopping results for hard drive enclosure.
    Hard drive enclosures can be PATA or SATA. Ensure you buy the right one, PATA is the big 40 pins IDE connector, SATA is the new small serial hard drive connector.
Windows will not start on my laptop
2 choices turn the comp over un plug the battery leave about 2 minits.
then plug back in and try again .
If that doesn't work then when it starts 2 boot up press F8 several times it will ask normal start or select last known good configuration & select it . if that doesn't work have u aback up disk insert the 4 th disk and boot from that insert tha disck turn off comp and re start it will come up boot from disc press any key yes thats shold b it
Oct 02, 2012 | Sony VAIO Computers & Internet
ASUS Eee PC 1001HA factory restore
start tapping f8 @ boot to see if you can get to boot menu, if it doesn't work then you'll have to get an external dvd player and boot from that to do a repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 12, 2012 | ASUS Eee PC 1001HA, ASU......
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
Tecra m7 doesn´t boot up
mine does the samething have you found out what the problems is yet?
Dec 23, 2008 | Toshiba Tecra M7 Tablet PC
32 people viewed this question
k24674
jasbo
jasbo
