Question about Dishwashers
Door catch Door closes but latch inside door panel does not lock in place so door will not remain closed. Appears that plastic part in door catch recess will rotate but is not under any spring pressure and will not lock in place.
  • Andy Thomas
    Andy Thomas May 11, 2010
    Hi. Can you tell me make and model number please?
  • 19,396 Answers
Hi.
Usually the spring is not sold as a single part.
You will need to replace the door lock.
Regards.
Posted on Nov 20, 2009
Whirlpool tud5700mq0 door not closing fully
there must be a problem with the lock or the catch or something has been pushed in the hole for the catch i would check that there is nothing in there first. they not adjustable when the door is closed a pin is closed on the lock when it is turned on for a was cycle.
Jun 23, 2017 | Whirlpool Dishwashers
Am having some "slack" when opening the latch. Can't see any debris around it. What now?
I have a very old Kenmore microwave. It's latches are plastic, probably Teflon due to temperature. They slide up to catch on
a metal "ramped anchor". I would check for problems with the recessed catches "ramped anchor" or the movement of the catches. There is also a micro switch lever that if bent or out of place might prevent the catch going in far enough. Or something in the door or the anchor have come loose so that it does not completely close.
Mar 21, 2015 | Panasonic NNSN797S Microwave Oven
Ford ranger door lock
Sounds like the door latch is not returning to the closed position.
Jun 23, 2013 | Cars & Trucks
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
I removed door panel to install speakers now the door wont close
You need to make sure the panel is on perfect. If it is a little off, it will catch the ends. Is the inner panel catching the door? If you added bigger speakers, it may catch on the inner part of the door, closet to the speakers.
Feb 18, 2011 | 2002 Dodge Durango
The locking mechanism on the rear passenger door isnt working.The door will close but the metal catch will not lock.How do i repair?
I have seen some times the latch assemblys get rusty or dirty and the inside or outside door handles are pulled and the latch assembly siezes in the open position not allowing the door to latch closed..but this may not be the case .. check to see also if the child lock switch position is not stuck in the halfway position, also check if the latch has not flipped to the close position before the door was closed thus jamming the striker latch..this can be fixed by pulling the catch out while opening the door handle..hope this helps good luck...
Nov 05, 2009 | 1995 Pontiac Sunfire
Door wont close
MAKE SURE THE DOOR LATCH IS NOT IN THE LOCK POSITION OPEN DOOR PULL THE INSIDE LATCH TO THE POSITION WHERE YOU WOULD TO OPEN DOOR AND TAKE FINGER AND TRY TO MOVE THE LATCH TO ANOTHER POSITION , HOPEFULLY TO THE POSITION WHERE IT WILL RECEIVE THE STRIKER POST OR THE PART THE DOOR WOULD NORMALLY LATCH ON
Feb 24, 2009 | 1991 Dodge Grand Caravan
Front door closes on a model R-1610-11-12 but light does not go out and microwave cannot be started up. Door does not seem to latch in place. In lower door latch inside the microwave I can see a plastic...
hi check that the door catch is locking into place maybethe locking mec is not engaging or triping the micro switch ,if it does n't trip the switch it won't turn light off and unit won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Dishwashers Logo
172 people viewed this question
Top Dishwashers Experts
Owen Barnes
