Question about Singer Sewing Machines
Sews about fifty stitches then misses two and continues then repeats
    Problem Solver:
  • 4 Answers
What fabric r u using???? If polyester try using a stretch eedle as this eliminates the static build up in the needle that causes the skipped stitches Cheers
Posted on Nov 20, 2009
Brother ST371HD Strong and Tough. Problem with SS (Stretch Stitch) setting.
Probably something amiss with your machine. Have you tried other stitches and how do they sew?
Feb 28, 2017 | Brother Sewing Machines
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
How do I cast off in knitting?
Take a needle several sizes larger than the ones you have used for the knitting - so the loops will be larger and the edge looser, knit the first two stitches onto the larger needle then use the tip of the other needle to lift the first stitch over the second one and right off the needle, so it is looped over the second stitch, but is no longer on the needle.
Knit another stitch and repeat the lifting over. I f you are casting off all the stitches continue to the end of the row and then cut the yarn, pass the end of the yarn through the last stitch and draw it up.
If you are only casting off part of the row then move the last stitch onto the right size needle and continue knitting on the stitches left in the row.
Dec 03, 2014 | Sewing Machines
Why does machine sew then stop after maybe 8 or 10 stitches?
You obviously have a faulty machine take it back to your dealer where you bought or directly contact Bernina.
Best wishes.
Aug 21, 2014 | Bernina Artista 640E Sewing, Quilting and...
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Janome Harmony 2049
Darning would normally be done with the triple stretch stich, the one that is a zig-zag broken up into three stitches right and then three stitches left. See-through Zig-Zag foot. Zig-Zag set at it's widest. Feed set to about 1/16-1/8 inch (1.5-3mm) and darn by sewing forward a bit, adjust fabric, and then backward by pressing and holding the reverse button. Continue back and forth until you've created a darned box. For extra strength, turn fabric 90 degrees and repeat over same area.
Jan 29, 2008 | Janome 2049LX Mechanical Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
