Xerox 5252 running
I have recently bought a xerox 5252 and was planning on running it myself after running 6 ap3800c before. However looking in the service book it seems a little out of my league.
Does anyone know how hard these machines are to keep operational or what I should expect to pay if I put it on a pay per click contract?
Thanks Mark
  • 1,110 Answers
You will need the contract. All Xerox machines made within the last few years unfortunately REQUIRE a XEROX authorized laptop computer in order to make any adjustments or to even get into the service mode. You can do the normal stuff and just pay by the call down the road when you need it but Xerox will charge you an arm and a leg for parts and labor.
If the machine is new, depending on your monthly volume you should expect to pay about 1 cent per page Black and 8 cents per page full color. Again these prices can vary based on your volume. The more pages you run the cheaper the cost per page.
Good Luck
Posted on Nov 20, 2009
Testimonial: "All good honest thanks"
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
System Fault Code 004-329
I have also had this problem with our Xerox DocuColor 6060. It ended up being a corotron charger was wiggling loose and I just needed to re-seat it. Maybe this will help. For us it was the Yellow...
Apr 17, 2013 | Xerox DocuColor 2045 2060 5252 6060 7000...
Xerox 2060 developer changing
error 010-314 and 010-315 for my xerox docucolor 2060-2045
Feb 25, 2013 | Xerox DocuColor 2045 2060 5252 6060 Cyan...
Xerox 2060 horizontal line ymc problem
xerox 2060 horizantal lines problem how do i replace the part
Oct 03, 2012 | Xerox DocuColor 2045 2060 5252 6060 7000...
I have a erro on my xerox 5252, pleas i need help, the error number is 009-344
Your docucolor has a problem whit the transfer belt. It may be damaged or out of position. Reinstall it correctly
Oct 29, 2009 | Xerox DocuColor 12 Printer
Vista printer driver for a Xerox Workcentre Pro 635
try this....
http://www.xpvistasite.com/workcentre_pro_635_12490.htm
Jan 04, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Error Code
Hi, all I know that is something about Xerographic components.
Try to clean printer inside,sensors etc.... and run some user adjustments.
Jan 17, 2007 | Xerox DocuColor 2006NPC Laser Printer
109 people viewed this question
k24674
