Have a samsung v25 had a problem with power outlet .had it in bits cured that problem but now the screen lights up but nothing shows . can hear it starting up etc
  • 71 Answers
Maybe check to make sure that you have reconected all the cables and have not caused any damage to the screen inverter
It all depends how much you removed when you had it in bits, so just double check that it all went back as it was ment to
Posted on Dec 01, 2009
    Sergeant:
    Champion:
  • 256 Answers
Check with external monitor whether there is display or not. if there is display in your external monitor check lcd or lcd cable.
thanks
Posted on Nov 20, 2009
Testimonial: "thanks very much"
Samsung v25 power on password
you should have been given a 7 digit number when it boots to password need this to get access code
Jun 07, 2012 | Dell Inspiron B130 Notebook
My laptop did not start it only show black screen
that happened to my mates laptop he had to go and get it repaired so goodluck:) please rate this solution...
Jun 06, 2010 | Samsung V25 XVC 2800 Notebook
Laptop screen too dark when used with battery
Are you using vista or xp?..The laptops to conserve power will dim the screen , you can , however, change it to brighter by pressing the "fn" key which stands for "functions"key. while pressing that, you should have another set of keys either to your right or obove your left finfers with the symbol fo a sun with arrows pointing up and down..press the fn and tap the up arrow key to increase the brightness.
Let me know if that works
Apr 10, 2009 | Samsung V25 XVC 2800 Notebook
Blank screen
Might be the VGA connector to the motherboard.
Turn upside-down. Remove screw in the centre marked KBD.
There are 4 screws running along the back. Remove the 2 inner ones.
Lever up the keypad with a small screwdriver - Careful not to disconnect the ribbon underneath.
Undo the 3 screws along the strip above the keyboard and remove the strip.
VGA connector is next to the power button. Check it is pushed down firmly.
NKYG
Dec 03, 2008 | Samsung V25 XVC 2800 Notebook
Samsung v25
Try to diagnose the problem first...
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
Aug 09, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Samsung v25 won't boot up
this is os or motherboard problem, reinstall the os
Nov 05, 2007 | Samsung V25 XVC 2800 Notebook
Samsung v 25 laptop
It sounds like your keyboard is setup as the US version, hence the keys being the wrong way around.
Go into the control panel, keyboard settings and change it to UK. That should cure your problem
Oct 18, 2007 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
