Question about Whirlpool Duet GHW9150P Front Load Washer
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
    President:
  • 1,891 Answers
Rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help, it worked like a charm."
  • dennis dodge Nov 20, 2009
    rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
  • fordy01 Nov 23, 2010
    job done thanks ,easy job too ,,--- tony
I have a whirlpool WFS1073CD and getting a red light indicator saying clean pump. It appears to be washing normally but wont go into the spin cycle. I have drained the water via the filter plug under
Hi Maureen
Wow.... at least this model has an indicator light telling you what the problem is. Many machines don't!
I think the reason it won't go into the spin cycle is that the water can't exit through the pump.
The usual cause is that a sock or something is caught or blocking the pump.
Power OFF of course.
Follow the drain hose back to the pump & try unclipping the hose off either side to feel for a blockage with your finger.
Pump blockage is a common occurrence in washing machines.
Good Luck
Nov 26, 2014 | Whirlpool Washing Machines
Red light saying clean pump...how?
Think the filter is located R/ h side bottom of machine this should come out and be cleaned,put an old towel under here first as water will come out...Good luck
Apr 21, 2011 | Whirlpool Washing Machines
Red light flashing,says 'clean pump'.water not drained away either.
Then you probably need to take pump off and see if there is something blocking it either in the hose from tub to pump or pump itself.
Sep 08, 2009 | Whirlpool GHW9100L Front Load Washer
My washer gets so far then says fp
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Red light on - clean pump
remove bottom panel 3 screws7mm once removed access to pump im front clean and reinstall thats it
Jan 03, 2009 | Washing Machines
Where is the pump on a whirlpool make washing machine?
remove the panel on the front bottom of your unit. it is the only panel you will see. Inside you will see a white pump unit with a cap that can be unscrewed. Once you remove it, water will drain all over so make sure you have something to catch it in and you will also get allot of junk out with the water. I found nails, money and other items when I cleaned mine out.
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
958 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
