Question about HP Office Equipment & Supplies
How do i set the size of print i want on a4 paper
  • 79 Answers
From the application which you want to print, select the paper size as A4.
Posted on Nov 20, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 145 Answers
Set the print size on Print dialog.
How do I reset my SX215 to factory settings
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
Feb 26, 2015 | Office Equipment & Supplies
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
    I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
    Jan 18, 2010 | Canon Office Equipment & Supplies
    If I place an A4 sheet on the scanner glass and press scan to print, the image appears on an A4 piece of paper - but at a tiny proportion of its original size. I can't see how to alter this. Can you help?
    check the setting, paper size may be set to a4 but the image may be set to a different size... like a bigger size maybe tats why only a part of the image is printed on the paper
    Sep 11, 2009 | Office Equipment & Supplies
    HP 4L when printing an internet page, print size is for
    Under print preferences set the paper size to A4.
    Start > Printers and Faxes > (Right-click printer and select properties) > (select printing preferences) > (set paper size)
    Aug 25, 2009 | HP LaserJet 4 plus Printer
    Load A4
    A4 is for european size, if you are printing on a letter size this is a mismatched.
    you need to change your files printer properties to A4 or letter size, or change your printer paper size.
    better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
    Jul 28, 2009 | HP LaserJet 2840 Printer
    Hp laserjet p3005dn tray1 manual feed problem
    you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
    Jul 25, 2009 | HP LaserJet P3005n Printer
    Konica Minolta 2490MF - Paper size error
    Need to set A4 size default on the printer driver itself.
    Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
    Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
    Click apply.
    should be o.k.
    Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
    44 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
