Question about Dishwashers
Dishlex Global 310 trips the circuit breaker at any time during wash. Fitter an RCD to the power point .. but problem still happens . Any ideas ?
    President:
  • 1,891 Answers
?? would have to see d/w to help with this problem .. could be a bad breaker / if its not the dw .. should call a service tec .. mm
Posted on Nov 20, 2009
I have a Dishlex Global 300 DW. The Mains safety switch trips on Rinse cycle. Heating element has continuity and works on wash cycle. There are no leaks.
call an electrician to check the insulation for ground leakage and breaker capacity for current use
it will most likely be tripping from moisture across the active and neutral wires somewhere
Dec 05, 2016 | Dishwashers
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
When using a lot of kitchen appliances at the same time the rcd trips , can i change the rcd to one with higher amps to stop this ?
You should only install a higher amp breaker if ALL of the wiring served by that breaker are of sufficient gauge to support the amperage of the breaker. For example the link below shows that a 20 amp circuit should have 12 gauge wiring (which has a conductor wire .08" or 2mm in diameter). http://www.cerrowire.com/ampacity-charts
Jun 21, 2016 | Kitchen Ranges
Bosch Classixx 1000rpm. Trips out RCD each time turned on. Am able to use other appliances in same power point. Only 3-4 years old
If the RCD is tripping then the appliance has an earth leakage fault. You should remove the plug from the power point and not use it until you get it repaired. This is a potentially dangerous fault, and the RCD is telling you it is faulty.
May 19, 2016 | Bosch Washing Machines
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Dishwasher power overload
Check heating element in DW and all parts associated with it located on the inside of DW under the spray arm. It could also be a problem with the control panel,Call technician.
Dec 09, 2007 | Dishwashers
Dishwashers Logo
313 people viewed this question
Top Dishwashers Experts
