Question about GE WSXH208A Front Load Washer
Will not spin or drain
Led's on timer on panel show that it is spinning and draining, humming from timer that's all. I was washing some pillows and one got hung at front right coner of machine between tub and sheet metal. Will wash and agitate fine? HELP.
  • GE Master
  • 19,396 Answers
Hi.
If the machine does not spin and drain , then it is usually a drain problem.
The stuck pillow may have released fluff from inside the pillow that may have clogged the drain system.
To fix the problem it is necessary to access the drain pump, undo the hose, and look for blockage in there.
The pump is accessed removing the panel at front lower side of the appliance.
The pump is located on the right side, have a container ready to collect water.
Disconnect the appliance from power before accessing the pump.
If the pump is OK, then the pillow stuck in the tub may have put under stress the motor assembly, damaging motor or motor control unit.
In this last case parts must be tested by a technician.
If you need to call a technician you can use the number listed on the owners manual.
On the link below you can find all parts and diagrams for your appliance:
WSXH208A0WW
Please do not forget to leave feedback.
Regards.
Posted on Nov 20, 2009
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
Sep 13, 2014 | LG WM2455HG XL Front Load Stackable...
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Wont spin or drain it only only hums when turn on
Either your drain pump is bad or something is stuck in it.  It won't spin until it drains so fix the drain pump, and it will spin.  You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Dec 19, 2009 | Kenmore HE2 Plus Front Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
Oct 17, 2008 | Frigidaire CWS3600AS Top Load Washer
Fridgidaire model fwx223lbs4 will wash, but won't spin fast and the water won't drain
HI thanks for the question it sounds like the pump is either burnt out or jammed with debris thanks the appliance doc
Sep 08, 2008 | Frigidaire CWS3600AS Top Load Washer
GE WSXH208A Front Load Washer Logo
26 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
