Question about HP DeskJet 5150 InkJet Printer
I have a hp 5150 desk jet that won't print. The task manager says "door open" which I see sometimes after I change out the cartridges. However, in this case I didn't. I've opened and closed everything twice. Pushed all the buttons. Cleared the print job and unplugged and plugged back in. Help....
    President:
  • 787 Answers
Open the printer cover.From right side there is a plastic rod.It's connect to door sensor.This plastic rod often breaks from top.Look that and if it's broke try to fix it with glue or something else.
Posted on Nov 20, 2009
HP Desk Jet F4280 Printer
In Windows go to the control panel and click Printers. If possible open the print spooler and check to see if Windows is "stuck" on the print job that was in progress when the printer jammed.
Sometimes Windows doesn't "let go" of the pending print job and it will prevent further printing if it didn't get the message that the jam has been cleared. You can also try disconnecting the printer, open and close the print door and also remove and reattach the rear panel (if your printer has one). Then reconnect the printer and see if Windows properly recognizes that it is ready to print.
Feb 26, 2015 | Hewlett Packard - Desk Jets HP Officejet...
My 5150 hp printer want print yellow light starts flashing i changed the color cart. still want print
there must be a problem on the mechanical system specially the cartridge carrier open the cover and check for any breaks on the belts replace them if any.
Aug 19, 2010 | HP DeskJet 5150 InkJet Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
I have 5150 it has full black cartridge not much color almost out I want to print in black and it will not goes trough the motion not print though just light blue.
Your description of the problem means that in your word processor you have specified color printing. Here you must change it to B&W. Then it will print black. Also do the same in Print manager.
Dec 11, 2009 | HP DeskJet 5150 InkJet Printer
I just changed my printer cartridges and I'm trying to print but I keep getting "door open" or "top cover open" message and nothing prints. My printer is a HP 5150
Open the cover.In right side you'll see the cover sensor.It's a plastic lever, which does down to the bottom of printer.The top side of this lever usually breaks.
Oct 13, 2009 | HP DeskJet 5150 InkJet Printer
I have the driver for hp desk jet 5150 but cant install my printe
Try installing through control panel and ( Fax/ Printers ) option.
Mar 19, 2009 | HP DeskJet 5150 InkJet Printer
Multiple probs w/ HP 5150
Try `driverguide` on the net.
Update your printer driver, this should solve your problem.
Also check the printer lead is ok
Feb 02, 2009 | HP DeskJet 5150 InkJet Printer
Error message
cartridge short. chek bleck cartridge
Jan 12, 2008 | HP DeskJet 5150 InkJet Printer
HP DskJet 5150 will not print black
re-install the print drivers. if it still doesn't print problem lies in the bubblejet power supply - not user fixable
Sep 06, 2007 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
408 people viewed this question
Seeker5211
Seeker5211
