Question about WYSE S10 (90210501) Network Terminal
Screensaver and autolock terminal
What do I descibe in the wnos.ini to lock the terminal after 10 min inactiv?
Wyse S10 and Wyse V10L
  • 154 Answers
SOURCE: Wyse S10 RPD to Server 2008
you have to buy 1 terminal license for you S10 also.
Posted on Apr 23, 2009
  • 25 Answers
SOURCE: wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
Posted on Jul 07, 2009
SOURCE: Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Posted on Oct 07, 2009
SOURCE: Citrix WYSE SXO terminal.
restart client
Posted on Feb 18, 2010
bronk50
  • 27725 Answers
SOURCE: How do you reset factory
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps
Posted on Jan 20, 2011
Wyse s10 an windows server 2012
Guys who need windows 10 key can go link http://windows10productkey.weebly.com to got. My key got here and after i used is great works. Hope it help you.
Nov 11, 2013 | WYSE S10 (90210501) Network Terminal
Getting a message about shadowing my session
The program you are using is telling the terminal to accept a VNC request, as it will send date on the port open for VNC. So the terminal is asking you to accept the prompt to allow a remote machine to control your session.
You can set the program to ignore the VNC ports, so it wont get prompted. Failing that you should be able to change the terminals behavior to the requests by editing the wnos.ini to not allow VNC connections. I think that can be done from there. Check on the config generator for wyse terminals on technicalhelp.de to find the correct syntax.
Jun 23, 2009 | WYSE S10 (90210501) Network Terminal
Thin Clients Have a Problem Connecting After Activating Licensing
Try using the command "fixlicense=clean" (think thats how its spelt, check with Wyse) in the wnos.ini.
See if this allows the terminals to relinquish any old TS cal and pickup a new one from your licensing server.
Jun 16, 2009 | WYSE S10 (90210501) Network Terminal
Wyse 1200LE - error - out of frequency
May 28, 2009 | WYSE Winterm S30 Network Terminal
Apr 23, 2009 | WYSE S10 (90210501) Network Terminal
WYSE S10 thin clients; we are hearing from users that when they hit the power button, the unit restarts instead. This behavior is also present using the gui interface. Not all units are doing this, but we...
Check in the BIOS, "Fireport" is the password. I cant remember if the power button behavior is set there or in the wnos.ini file.
You can check the config generator on technicalhelp.de to see if the command is in there for the wnos.ini
Apr 07, 2009 | WYSE S10 (90210501) Network Terminal
I have some problem with my monitor frequency and wyse terminal frequency.Its overrange, i can't see anything when i power it up.Can smbd tell me how to reset factory default with power on.
Feb 22, 2009 | WYSE WINTERM 1200LE Network Terminal
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
WYSE S10 (90210501) Network Terminal Logo
212 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
