Question about Baume Et Mercier Baume & Mercier Hampton Chronograph MOA08479
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
  • 3 Answers
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Posted on Dec 01, 2009
  • bigg5316 Jun 07, 2011
    Thanks, tried several ways, does not work. I believe because this is an automatic watch it needs to be opened, and the wheel adjusting that sub-dial needs to be adjusted. Thanks for your help, it is appreciated. Gary
    New Friend:
Pull the crown to position 3 (fully out) and press push-button P2 (reset button) successively until the hand of the tenths-of-a-second counter returns to its correct position. Put crown back into position 1 (fully in).
Pull the crown out to position 3 and press push-button P1 (start/stop button) succesively to reset the chronograph seconds-hand. Put the crown back into position 1.
Pull the crown into position 2 (not fully out) and press push-button P2 until 30-minutes counter returns to zero. Put crown back into position 1.
Posted on Jul 22, 2013
    New Friend:
Model: Classima Executives Quartz Chronograph
1) pull crown out to position 3 (most pulled out)
2) press and hold both buttons till the seconds dial makes a full flyback. Chronograph is now ready for reset
3) Keep pressing P1 button (for starting/stopping of the chronograph) until the seconds dial is at "0"
4) Press P2 button (for resetting chronograph) to switch to resetting the next dial - the 1/10s dial.
5) Keep pressing P1 button (for starting/stopping of the chronograph) until the 1/10 seconds dial is at "0"
6) Press P2 button once again to switch to resetting the next dial - the 30 min dial.
7) Keep pressing P1 button until the 30 min dial is at "0"
8) push the crown fully back in.
DONE
Posted on Jun 14, 2015
What are the three little faces for? do not have instructions
Your watch is a chronograph or a watch that includes a stopwatch. Two of the three dials are for recording minutes and hours with the large sweep second hand recording seconds. Pushing the upper button starts and stops the stopwatch function. Pressing the lower resets everything to zero. The small bottome dial is the seconds hand for the watch, it always is moving.
Dec 29, 2011 | Callaway Golf Unisex CY2085 Collection...
On my new Victoronox 24332, the sweep hand for the stop watch does not reset to zero but rather to about 17 seconds past '12' O'clock. The split second hand also stops just past Zero on...
Follow the instructions on the following link. I believe it works on all or most Swiss quartz chronographs. Worked like a charm for my Mondaine and my Zodiac. Hope it works for you too.
http://mondainewatch.co.uk/my-chronometer-doesnt-go-to-zero.html
May 26, 2011 | Swiss Army Base Camp 24332 Watch
The seconds hand doesn't reset to zero when you activate the chronometer with the pusher A and stop it with the same one, you can reset with the pusher B, but it doesn't reset to zero y goes to...
CROWN SETTINGS:
1....... Running position/screwed
2 .......Date correction
3........Time correction
Procedure to set the mode using Push Buttons
Pusher A: Start/Stop Chronograph
Pusher B: Change to Chronograph mode/ Reset to zero
Note if by pressing button B and it doesn't reset to zero, you can adjust the time by following the procedure below
1. Set crown to position 3
2. Press pusher A to realign second hand
3. Press pusher B to realign counter hand at 6H
Note: For faster hand adjustment, hold pusher for 2 seconds or more
Hope this information will help you!
May 17, 2011 | Technomarine Us Navy NAUT05 Gents Watch
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
The seconds hand will not zero when reset
The chronograph can be reset by pulling out the crown to the first or second position and pressing the start button or top button. This will begin to move the sweep arm and you can stop it on the 12:00 or 0 position. Make sure that when you have the battery changed they do this for you.
Sep 22, 2009 | Watches
My Movado Series 800 second hand zeroes out at the 3-second spot, not at zero (12).
Sep 17, 2009 | Movado Series 800 Watch
With "The Producer" Nixon watch, can you reset the main stopwatch hand to zero? It resets to +4 second position.
Pull out the crown to the first or second set position then press and hold down the start button. The sweep arm should begin to move into the right position. Once it is at 12:00 or 0 release the button and press the crown back in.
Sep 12, 2009 | Nixon Producer NIX0022 Wrist Watch
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Baume Et Mercier Baume & Mercier Hampton Chronograph MOA08479 Logo
856 people viewed this question
Top Baume Et Mercier Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Baume Et Mercier Watch Expert? Answer questions, earn points and help others
