Question about Nokia 5800 XpressMusic Smartphone
SETTING GPS ON NOKIA 5800 - Nokia 5800 XpressMusic Smartphone
How to reset nokia 5800 xpressmusic
I hope that you mean to Reset your phone to default setting.Ok here if it's true follow this: type *#7780# enter security code 12345 or what you have made.Or select "Restore setting only" from the phone setting.Good luck
Jul 19, 2012 | Nokia 5800 XpressMusic Smartphone
I forgotten factoy setting code on nokia 5800 xpress music
default code for factory setting in nokia are either 12345 or 00000.
if you have'nt changed code then these will surely do for you.
hope this is helpful
Feb 10, 2011 | Nokia 5800 XpressMusic Smartphone
Dear sir, i format my nokia 5800 some other i...
i think there must be some missing on the configuration message. Try for another same setting message
Thank you.
May 20, 2010 | Nokia 5800 XpressMusic Smartphone
My Nokia 5800 Xpressmusic has frozen on the "nokia start up screen". What should I do?
hi the only thing to do is to reset the phone to factory setting by pressing the green button the camera button and the on/off button simultaneously
May 21, 2010 | Nokia 5800 XpressMusic Smartphone
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
I am using the 5800 xpress .Setting and some other icon missing in my phone.How can i get it back?
well u can restore your cell try this way
5800 Hard Reset
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
Mar 02, 2010 | Nokia 5800 XpressMusic Smartphone
China 5800 xm nokia not getting gprs and wap giving me
try using setting wizard to configure your gprs setting.hope this'll help.
Feb 11, 2010 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 v20 problem with music
reinstall firmware again.(I was succesfull 3rd time).
Jul 03, 2009 | Nokia 5800 XpressMusic Smartphone
NOKIA 5800 GPS PROBLEM
Hi all I have a solution for fixing the internal GPS for the Nokia 5800. It will work as long as you leave the power on. If the phone is turned off you will have to repeat this very simple process. 1) Select Applications, and then open the application called, Location. 2) Select positioning. 3) Select positioning methods. 4) Tick Integrated GPS and Assisted GPS. 4) Select positioning server and Select automatic. Select access point and select. Then select gps data. Select options and select satellite status. When you have a satellite lock. Repeat 1), 2) 3) Then select Integrated GPS (ONLY), untick Assisted GPS.
What you have basically done here is lock onto the satellites through GPRS (phones internet). Then disconnected from the internet and still get a lock on the satellites just by using Integrated GPS. Hope this helps someone and someone can take this concept to get a better understanding of what and why this is happening. Maybe some wizard can create a phone patch.
Cheers to all, Colin Nelson, Kille, Scotland.
Feb 11, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
331 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
