Question about Nintendo DSi Black Console
When i turn it on a message comes up saying an error has occurred. press and hold the power button 2 turn the system off. ive tried this a few times but the problem still keeps reacuring .
    Sergeant:
    Champion:
  • 212 Answers
Game slot may be dirty. Try to clean and try a game. Good Luck
Posted on Nov 20, 2009
D7160
error 0xc05d1281 mean the ink system failure
try blow reset Solutions
Solution 1:
  • Press and hold the "*" key.
  • Press the "#" key and release both keys.
  • Display should say "Enter Special Key Combo"
  • Press and release in sequence the "1", "2" and "3" buttons.
  • Screen says "support" R0631M
  • Press and release the right arrow button until the display says "System Configuration Menu".
  • Press and release the "OK" button.
  • Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
  • Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
  • Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
  • Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Solution 2:
  • Press * and # at the same time
  • Press 1, 2, 3 and "support R0632M" should display
  • Press > and "information menu" should display
  • Press > and "configuration menu" should display
  • Press OK and "hardware failure status" should display
  • Press OK "failure status: clear". Press OK to clear
  • Press CANCEL
  • Press CANCEL
  • Press CANCEL
  • Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
  • If the error came back, do the sequence again and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Solution 3 (thanks to a1224imac):
  • This same error started occurring on my printer and eventually it would constantly poweron and off.
  • Apparently some defective components were used in the construction of the logic board (see photo).
  • On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer).
  • I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents).
  • On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662.
  • If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Jul 22, 2014 | HP Photosmart D7160 InkJet Printer
Ink system failure error message Oxc18a0106. How do I fix this?
Hello.
Try this
Hewlett Packard Ink System Failure Error Fix (tested C6180) 1- Press and hold the "*" key. 2- Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3- Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M 4. Press and release the right arrow button until the display says "System Configuration Menu". 5. Press and release the "OK" button. 6. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 7. Press and release the "OK" button. 8. Display should say "Hardware failure status: Clear. Press OK to clear". 9. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 10. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 11. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 12. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 13. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
I hope this helps Regards GM
Jul 15, 2011 | HP Photosmart C7280 Printer
Every time I try to print I get an error message as follows: Error Message 1700: Waste ink absorber is almost full. Press resume to restart. My manual says nothing about a "waste ink absorber" so...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Nov 18, 2010 | Canon PIXMA iP2000 InkJet Printer
On the printer small screen it gives me this message. Ink System has failed. Unable to print. Refer to documentation error 0x05d1281 A short time ago a paper jam occured, I believe this current problem...
You can try clearing this error by resetting your printer. Follow these steps, Its worth a try.
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say “support” R0631M”
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer
will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Let me know if this help you.
Thank you for using Fixya.
Aug 21, 2010 | HP Photosmart C6280 Printer
Error ink system has failed,error 0xc18a0401. this
Please follow the below steps and the issue will be fixed. STEP 1. 1. Un plug the power chord from the back of the printer. 2. Press and hold the power button of the printer.Wait for 30 seconds. 3. While holding the power button, re-plug the power cable. 4. Turn on the printer, if it is not on. STEP 2. A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) 2. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen 3. Press and release the ?OK? button. 4. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 5. Press and release the ?OK? button. 6. Display should say ?Hardware failure status: Clear. Press OK to clear?. 7. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 8. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 11. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. 12. If the printer has already initialized, then go to the next step. If not, the printer will start the ?ONE TIME INK INITIALI-ZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 13. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation. Please come again and give the vote if the issue is fixed as it will really motovate me to help people.
May 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
Every time I try to play a game the screens goes black and it says; an error has occurred. Press and hold the Power Button to turn the system off. Please see the Nintendo DSi Operations Manual for help...
Every time I try to play a game the screens goes black and it says; an error has occurred. Press and hold the Power Button to turn the system off. Please see the Nintendo DSi Operations Manual for help troubleshooting. But I don't have the manual, ca anyone help me please.Thank you!
May 12, 2010 | Nintendo DSi Black Console
I have just changed the ink in my printer and I have received an error message C18a0206. I can't locate this in my documentation. What is the problem?
PERFORM THE FOLLOWING STEPS:
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
1. Press and release the right arrow button until the display says “System Configuration Menu”.
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
May 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
DSi-ttds-error has occured message
Hay ive had the same thing 2 except my brother did sytem update nd the card dont work (i hav ttds 2) im 13 and im upset 2
Oct 01, 2009 | Nintendo DS Lite Console
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart C6280 All-in-One i have an Error massage (Ink System Failure)it says: ink system has failed. unable to print. refer to printer...
ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
Oct 02, 2008 | Office Equipment & Supplies
Nintendo DSi Black Console Logo
393 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
