Question about Dell E772p Monitor
Monitor no display
Horixzontal driver transformer supply resistor 180ohms (3621)burns of and driver transistor bsn254 (7605) gets shorted.
    Problem Solver:
  • 6 Answers
I would suggest retouching the solder joints on all components in the area of the affected components. Sometimes solder joints weaken and put additional stress on other parts. This is a common problem in many Dell and BenQ LCD monitors.
Posted on Dec 03, 2009
Sharp tv primo 21`inch turn on red light only
check your horizontal transistor maybe it's shorted replace horizontal transistor or maybe the fusible fuses are open check for open resistors at the horizontal section of the circuit.
Dec 22, 2010 | Sharp Televison & Video
No display on monitor; green switch keeps flashing
You may have shorted out transistors in the inverter circuits, common problem.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 28, 2010 | Dell E173FP 17" LCD Monitor
Samsung syncmaster 914v monitor problem. Right side of display is darker image. Can see dots like a newspaper print or looking through a screen. When display is black it almost appears like an image is...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
I replace horizontal output transistor with new one but it happens the same short
check yoke coil for open ckt, and and check for 12 v dc supply to vertical circuit, sometimes resistor open that supply dc voltage coming from flyback transformer.
Apr 27, 2010 | Televison & Video
My LCD monitor is blinking green but no display is coming, some days back after blinking 15-20 minute display comes. But now display not come
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 09, 2010 | Dell UltraSharp 1701FP 17" LCD Monitor
Krell kav 250A blows internal fuse
hi please check the wiring of the output it could be short or the speaker would be short or it could be the diode at the secondary supply that had short or capacitor disconnect the power supply ans check the OHMS of the transformer .or check the transistor could be stort
Nov 17, 2009 | Audio Players & Recorders
Sony kv32s26 While tv was off (had been for 10 hours) there was a very loud snap--burning electrical smell. TV now will not turn on
The switch mode power supply has failed in it. That section also provide standby voltage for your TV so that it will turn on when you use the remote. These power supply are driven by Field Effect Transistors, switching at up to 200 thousand times per second, and they are very efficient. There is a transformer usually that has ferite for a core. The Transistor has shorted out on it, and thats where the burning smell came from along with the resistor. The transformer may have been burnt too. It is possible for a someone to fix it, but he/she would have to be familiar with electronic components on television. It is not a job for a handy man type of guy.
Jun 28, 2009 | Sony KV-32S26 32" TV
Monitor not Display
Hi Rey,
Hope this helps you like what I did to resolve this kinda problem. If you can manage to open the chassis/cover check first if the HOT (horizontal output transistor) is good, if good check the SMPS (switching mode power supply) primary and secondary side if there are short filter capacitors, diodes, transistors and open resistors. Major faults to consider is by checking the load of SMPS, control circuit, driver circuit, feedback ckt.
Please let somebody to assist you (a certified technician) how to open the chassis safely due to electric shock. Please be guided accordingly.
Best regards,
Rosener Guyano
Jan 30, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Dell Monitor problem
check the secondary section, something is short. not sure what it is may be 5 volts regulator exceed voltage, EHT transformer drive transistors are short (some used the SMD) or may be the Power supply is not giving proper voltage (not able to take load).
Jan 06, 2008 | Dell E173FP 17" LCD Monitor
Sony KV-32S40
When the horizontal output (2SC4927) is shorted it means one of 2 things is wrong - the horizontal drive transformer has cracked solder joints or the flyback transformer is shorted inside. If the solder joints on the horizontal drive transformer (the small grey transformer connected to the base of the horizontal output transistor) are cracked then the set will play for a little while and then the parts you just replaced will again be destroyed. ALWAYS resolder the driver transformer when replacing the parts you mentioned! When I replace the parts you mention and I do not see any obvious cracks on the driver transformer then I unsolder the B+ pin of the flyback (labeled 135, for 135 volts) and put a 60 to 100 watt lightbulb (drop-light) in series with the flyback. This means that the 135 volts B+ goes through the lightbulb and then into the flyback, so the lightbulb acts as a current limiter to protect the horizontal output. When you turn the set on the bulb should glow no more than about half bright and you should hear the high voltage come up, but you should not see a picture. If you turn the set on and the bulb glows as bright as if it was plugged into the wall then you can bet that flyback is shorted and must be replaced.
Jul 12, 2007 | Sony KV-32S40 32" TV
Computers & Internet Logo
66 people viewed this question
Alun Cox
