Question about Sony KDF-50E2000 50" HDTV
When i connect my computer to the tv it comes up with a green tinge, a bit of ghosting how can i make it better?
My lg tv has a green tint to the screen
Sounds like a bad T-Con board which is the board at the Top-Middle of the set. I have also seen the display bad causing that problem in Lg's. Have it looked at first.
Mar 06, 2013 | LG 47LV5500 47-Inch 1080p 120Hz LED TV...
My acer tv has a green sreen which is happening afer failing to start up properly for soe time.
Failing power capacitors causing slow start up time and the green tinge points to a failing graphics chipset. The monitor is most likely due to be replaced
Jul 18, 2011 | Computers & Internet
Sony bravia kdl40S504 has green ghosts - cannot
I do not think that cause by power surge, and it is on manufactory warranty, you better to call Sony.
Jun 26, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Ghosting and blue tinge on close up on people
It is fixable depending upon the make and model.
Mar 28, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Green cruve line
Good Day;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 31, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
New samsung 37"lcd the picture leaves a ghost when people move on screen i have tried to fine tune but nothing what can i do as im a bit thick when it comes to these things.
TV has a slow response time. Only cure is to buy a faster one.
Look for the response time of the TV in the description.
The lower the better. 12 mS is slow 4 mS is faster and smoother.
Mar 15, 2008 | Computers & Internet
56 inch Panasonic Projection TV
Hello stonehor,
Do a quick check on your cable wire. Make sure they are all pushed in properly both on the cable box and on the TV connector. What we have found is that these cable are not pushed in all the way. If this happened on both component input, you may have an open connection further back on that input board.
Best regards
circuitcity
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Sony KDF-50E2000 50" HDTV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
