Question about Roper REK2950W Electric Dryer
I have a Kenmore Model apartment dryer.
I have been searching for the correct lint basket for the inside. The dryer is practically new but they make the one part that is touched the most out of cheap pleastic that cracks. It is not round nor square...it's kind of looks like a spit pan (so sorry to say it that way) that they give you in the hospital without the curve or a pear without the curve..the basket fits into a top that has two small, weak little plastic pieces it's suppose to push under...well, once one of those waste of money plastic pieces breaks off....your sunk....also, I would like to buy an inside vent. So, if you can help me out I'd much appreciate it. If the model number helps any it is Kenmore-11084722401 and thank you.
Thanking you for your time and please put Brandy in the subject line or it may end up in spam and I may end up in the nut house.
Respectfully
    President:
  • 1,891 Answers
Brandy you can get the filter you want from a coin opp dealer . or a appliance parts co that deals in coin opp . kenmore / roper / whirlpool / ect / use your model # . mm
Posted on Nov 20, 2009
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
How to clean lint out of inside of Kenmore Oasis Elite dryer
Here is a "youtube" video showing how to take the dryer apart. Right around 3:20 is where you need to take the plactic cover off to be ablwe to clean all the lint off.
Jun 26, 2014 | Kenmore Elite Oasis ST 7806 Dryer
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Model 110.68422700; the dryer cycles all the settings
when was the last time you cleaned out the dryer?you should clean the dryer once a year anyway so try this,unplug the dryer,remove the lint filter,take out the 2 phillips screws in front of the filter on the top panel.pull out the dryer,remove the vent line from the back of dryer and remove the back panel.on the left side you'll see the duct that the filter slides down into,take out the 4 screws that hold it in and remove it and clean it out,vac off the back of dryer,if you have a shop vac put it on blow and blow out the blower wheel and the heater and blow out the duct to get it clean.if the vent line is long i use a leaf blower to blow out the vent line,go outside first and make sure the duct outside is not blocked with any lint or anything and make sure the flapper opens freely.put it back together,except for the 2 phillips screws on top,with a screw driver pop up the top panel,there are 2 clips on each side that locks the top panel to the frame,just stick the screw driver in between the front panel and the top panel and pop it up,you'll see 2 5/16 screws one on each side around 4 inches down from the top on the inside,remove them and disconnect the door switch harness,use a screw driver to stick in between the harness to pull it apart to make it easier to get it apart,pull up on the front panel one side at a time and remove the front panel,vac out the inside of dryer,blow off the motor and blow all the lint from the back to the front so you don't have to pull the drum,if you know how to reinstall the belt take out the drum,the timer moves when the heat shuts down but if the dryer is loaded with lint the heater will not run correctly because of bad air movement and the clothes won't dry so try this first and let me know what happens
Apr 01, 2010 | Kenmore Dryers
My Kenmore ELITE keeps shutting off before the
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Aug 18, 2009 | Dryers
Help getting kenmore dryer apart
remove the two top lint screen screws,pull the top toward you and up,remove the two front panel screws one on each side top,disconnect the door switch,pull up and out and your in the dryer,let me know if you need more help-mike
May 27, 2009 | Dryers
Kenmore dryer model 64781 no heat
if it is a top mount lint filter you can remove the back to get to it,if lint trap is inside the dryer you get to it in the front-do you have a meter?mike
May 21, 2009 | Kenmore Dryers
Disassembling a kenmore dryer
does it have a top lint filter or a inside the front lint filter-?-mike
Oct 21, 2008 | Dryers
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Roper REK2950W Electric Dryer Logo
80 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
