Question about Progressive DVHE210 210 DVD Player
Progressive scan model dv1130 progressive scan is on screen setup menu will not show I have held stop button for more than two minutes. it does not solve the problem
  • rzrart Mar 19, 2008
    i have a problem with my dvd player! i accidentally put it on progressive scan and now, no images can be seen how can i get it back to the interlaced mode??? need answers asap ty! my dvd player is a pioneer dv 393 s
I have a zenith dvd/vcr receiver model LH-C245M i accidentally put it on progressive scan mode and appears on on my TV screen how can i get back to normal viewing? can you help me with this one Please. Thank you hoping for your great response.
Posted on Jun 26, 2008
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Progressive Scan Mode
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
Jan 29, 2008 | Zenith XBS344 System
Progressive Scan
Please go to the following link for an exact definition and how it is applicable to your situation. Please read all 3 pages of information!!!!! The short of it is, is that your TV may not be set up for progressive scan. Try turning off progressive scan on your DVD player's menu and see if this works.
http://hometheater.about.com/od/beforeyoubuy/a/progressivescan.htm
Jan 03, 2008 | TruTech TT1620 DVD Recorder
I need to know how to get the progressive scan feature turned off so I can view DVD's.
Thanks for the progressive scan advice. I have a Go-Video DV1130 Combo I didnt have a DVD in the combo and I pressed and held the stop button on the combo instead of the remote and it came out of the progressive scan mode so maybe it works both ways? But anyway Thanks for the advice it sure helped me.
Dec 31, 2007 | GoVideo DV1130 DVD Player/VCR
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
PROGRESIVE SCAN
I have the samne problem, hoiwever when I press the menu/setup button it says setup on the display but nothing changes on the tv, it does not have a navigation menu, any suggestions on what to do to remove the progressive scan from my screen
Nov 05, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Oct 23, 2006 | Zenith XBV442 DVD Player/VCR
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
Progressive DVHE210 210 DVD Player Logo
147 people viewed this question
Top Progressive Televison & Video Experts
Are you a Progressive Televison and Video Expert? Answer questions, earn points and help others
