Question about Hoover Washing Machines
Bad smell inside drum - Hoover Washing Machines
    President:
  • 1,891 Answers
Most front loads have it and if they don't they will . use whirlpool;s fresh tab. ( they work ) .. any appl dealer. mm
Posted on Nov 20, 2009
Smells like electrical inside the drum
Do you have heat in the Dryer still? If not and you have the smell the heating element probably blew a fuses due to lint build up. or the heating element itself is bad.
Nov 13, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Why does my Whirlpool H2low washing machine smell bad inside?
Are you sure it's your washer or is there an awful sewage gas smell coming up your drain where your washer hose drains in.. I had this happen and I had to instal a U trap in the line the washer drained into.
Sep 09, 2014 | Washing Machines
Bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
Nov 18, 2011 | LG WM-2277HW Front Load Washer
Hello - I have a Bosch Classixx 1400 and it smells bad! What may be causing this? I have emptied the black tube with water in adn I have unscrewed the plug on the right and water came out of here but the...
Hi.
The smell will be coming from inside the drum as you summised.
It is probably caused by the drain in need of cleaning, or more likely a build up of dirt and scum on the door seal cased by doing too many low temperature washes.
Check the seal carefully and if it is stained black, then the only real solution is to replace the seal, and do more high temperature washes
Jan 16, 2011 | Bosch Washing Machines
Inside of washer smells bad!!
Your smell is inside the washer under the cabinet. You must take the cabinet apart and thoroughly clean it. You must have a small leak that has been going on for sometime now for the moister has mildewed. Lysol will kill the smell on this although it must be cleaned first of all
Apr 28, 2010 | Amana NTW4500V Washer
Really bad smell from drum?
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the hose to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting. Being the first time you shd note what you doing, what goes where. You certainly don't need techs for this; and techs who come are useless anyway.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pl give me a ‘very helpful’ rating for the free help, thanks!
Mar 08, 2010 | Hotpoint WMA64 Front Load Washer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
A bad smell from inside
A lot of machines can suffer from this problem. It is usually down to a bacteria build up between the drum and the tub.The majority of appliances that suffer form this have been used mainly on 40 degree washes and with a biological detergent.
The best way to get rid of this smell is to place two tablespoons of washing soda or soda crystals in the detergent drawer and then run the appliance empty on the 90 degree wash. You may have to repeat this treatment several times before the smell goes but it will go eventually.
Dec 30, 2008 | Ariston Technologies AWD121WH
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
