Question about Dishwashers
Our KitchenAid Superba model KUDS01DJss0 ( about 7 years old and has always worked fine) I think is not heating . . the dishes come out wet and don't seem very clean if they had especially if they have a small a bit of something like peanut butter on them when loaded ( so lately I've been dong a pre-wash by hand). Unit doesn't seem to get very "hot" during the wash/dry and steam does not billow out when I open the door soon after the cycle completes like it used to. It does feel warm to the touch perhaps because it is connected to the house hot water? So, I think the heater needs to be replaced, but do I also need to order the control board or any other parts? Any tricks or "need to know" items to getting the unit out and to the things that need replacement? How long would this take for a mildly techy person with no super special tools? Final advice - if this is going to take 5 + hours, then for me it might be worth just calling a service guy ( unless that would nearly amount to the cost of a new washer). I'd be OK spending $ 250.00 vs spending 5+ hours, but don't want to pay 800.00 when I can almost get a new washer for that. So, is it pretty easy to do it yourself or ??? Your suggestions are much appreciated! Thanks Britta
  • davenbritt Nov 20, 2009
    thanks - what sort of replacement unit would you recommend (?) I like your ideas and the less water power etc. can we get a stainless exterior look for that?
    Thank you - this looks good
  • 10,865 Answers
Hello. The new heating element will come with a new control board. There are no tricks to the change actually, the easiest way to change the heating element is to unhook the plumbing, electrical, and drain hose then pull it out and get to the back oc it where there are plastic nuts which hold it in place. just unscrew, remove, remove the wires that connect to the heater terminal first. Your cost should be well under 200 dollars. That said, the only other considerations are that you can get a very nice new unit these days on sale for under 500. AND these new units are incredibly quiet, use much less water, much less power and do a fabulous job. Either way good luck with it. Regards, joe
Posted on Nov 20, 2009
Kitchenaid superba stove
check your safety thermo it is at the rear of the range
Dec 09, 2013 | Kitchen Ranges
KitchenAid KGSC308LSS Gas Kitchen Range OVEN won't heat up
Does the igniter in the oven glow white hot when it tries to start?
Dec 20, 2012 | KitchenAid KGSC308LSS Gas Kitchen Range
The icemaker on my KitchenAid superba KSBS25in does not work
Their might be an easy fix here. Try a hair dryer. heat the ice maker and dislodge a possible stuck ice cube( a common problem)
More HERE
Dec 15, 2009 | Kitchen Ranges
KitchenAid Superba leaks from filter housing
i would definately change the filter
they are usually only good for 6 mos
or 400 gals
without knowing if its dripping from the housing
i would start with changing the filter and see if that takes care of it
AP3182816
i just checked and thesea re on sale
30.00 is pretty cheap
appliancepartspros.com
i used to sell these off my truck as a maytag guy
for 48
let me knoe
Oct 17, 2009 | KitchenAid Superba Architect KSCS25IN Side...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
No heat when timer is in Electronic Sensor selections.
The electronic sensor needs to be replaced.
Sep 16, 2009 | Dryers
Superba Kudso15l551
check the check valve it may have something in it.
Jun 10, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwashers Logo
178 people viewed this question
Top Dishwashers Experts
Owen Barnes
