Question about Frigidaire FWS833A Top Load Washer
Sometimes the machine just fills up with water, doesnt spin but continues to fill up and then leaks it out through the bottom, this happens especially when i try to wash with full load
  • 26 Answers
The FRIGIDAIRE washing machine as in all washers have what is called a WATER LEVEL SWITH. This switch is on the top and this is where you select small,medium or large water levels. This water level switch has a clear hose from the top of swith to the side of the out tub. Please check the following:
1- check that the hose is hooked up on both sides and inspect it that it does not have any holes.
2- There could be a small sock or something foreign in between the inner and out drum therefore clogging up this hole.
3- Replace the water-level swith.
Posted on Nov 20, 2009
Kenmore 80 series,CH2874165. Continues to fill with water and never starts to agitation. Will spin and drain no problem
In order for the filling to stop and the wash programme to begin, the brain needs to know there is enough water in the tub. There are a variety of methods of detecting the tub water level - pressure switch, float switch or electronic moisture detector.
These things tend to be placed outside the tub and connected by narrow hoses that sometimes perish and leak or become blocked with residue. Sometimes the switch itself fails...
May 29, 2017 | Kenmore Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Indesit iwb5113 keeps filling up
The water level in your, and most other, washing and dishwashing machines is controlled by an air pressure switch that senses water level by the rising air pressure compressed in the pressure, (level), switch body itself. This air pressure is usually transmitted by a thin rubber tube on the bottom of the washing machine drum, or sump hose. As the water gets higher in the drum, air is compressed in the level switch until it operates, and turns the fill valves off. The pressure switch is always mounted at the top of the washing machine cabinet - look for a circular switch with the thin rubber or plastic tube fitted into the bottom. What can happen is if the rubber tube rubs against moving parts in the washer, it can get a hole worn in it - so the air does not compress and the water doesn't turn off.. You will have to examine the tube very carefully to find holes like this. Alternatively, the tube could have come off, or blocked with limescale at the bottom end - try removing the tube at the pressure switch end and blowing through it - any blockage must be removed. A last, rare, possibility is the rubber diaphragm in the pressure switch is leaking - but very very rare. Most modern machines have an electronic backup that measures fill time in case the pressure switch fails. If your machine floods, it doesn't have this.
Jan 19, 2018 | Washing Machines
My Hoover500MB washing machine sometimes doesnt agitate or spin but will empty and fill
99% of those problems are with the lid switch. Check make sure it is functioning properly.
Oct 03, 2012 | Washing Machines
The water is on but the water doesnt fill the washer. the spin cycle works how do i get the water to fill the washer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | Maytag MAV8557 Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Water leaks out of bottom of washer
The screw in the washer tub, is not a factor in this. I'm not sure what brand of machine you have, but several machines have a fill hose that connects to the outer tub of the machine. Sometimes when a machine gets loaded heavily, during the spin cycle items in the machine can actually knock the fill hose right out of the tub. Then when the machine trys to fill the next time, all the water runs down the outside of the tub and leaks out of the bottom of the machine.
Repair is to open up the machine. You'll need to remove the top cover and that will give you access to the hose/tub connection. It may be as simple as reinserting the hose back into the drum or you may need to replace it if it got too damaged and won't stay in the hole correctly.
If you need specific how to's on opening up the machine, get back to us with the make and model info and we'll be happy to help you open that washer up!
K
Aug 01, 2009 | GE Washing Machines
I have the same problem , the water filled then stopped working ,
sounds like your timer burnt out or is sticking somtimes giving the top of the controll box a firm smack will get it freed up
Jun 28, 2009 | Maytag Performa PAV2200
Help Please!
2 screws across the bottom of front panel will allow the front panel to slide off, then you can get an idea *** to where the leak is happening. fill with just a little water and advance to spin
Mar 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FWS833A Top Load Washer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
