Question about Motorola Mobility RAZR V3
Backlight on screen not working - Motorola Mobility RAZR V3
  • 10,865 Answers
Hello. I can assist you. First of all, if you have had the phone for under one year, take it back to the store as it is still under warranty. Older than one year you may have to pay a small fee to have it repaired. This backlight is interesting in that it is controlled by a tiny photoelectric cell in a little hole on the face of the phone. That said, if you are in a very bright environment, the photo electric cell will tell the back light not to come on. hope this helps. Regards, joe
Posted on Nov 20, 2009
My friend has a 50inch philiphs tv the sound works but no image is there anything anyone could advised
Is it a LCD type screen? If it is, look close, is there no backlight, or its lit with no image? If its no backlight, the screen backlight inverter is bad. If there's backlight with no image, can be the display, connection cable or mainboard.
Jan 11, 2013 | Televison & Video
Backlight dosnt work on the screen but the rest of the unit works
backlight is burned out repair should be about $150 through an authorized service center.
Jan 24, 2010 | Pioneer Car Audio & Video
Iphone screen backlight not working. What to do?
If the backlight on your Iphone is dead, you need to replace it. This does usually happen if it received a sharp drop or exposed to liquid.
Check out the following link for your repair options
Repair Backlight on Iphone 3g
Jan 09, 2010 | Apple iPhone Smartphone
W2242T's backlight not working...
You can buy backlight fluorescent bulbs on eBay.
Jul 04, 2009 | LG W2242TQ-BF 22 inch Monitor
Backlight is off
You either have a bad LCD or bad backlight board. The backlight on your screen is no different than a light bulb. If it burn out it stops working, if these is no power to the backlight your screen will have an image but no backlight to see the image.
Jul 03, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Backlight on the screen not working
there is dim light on the screne
Nov 12, 2008 | Nokia N95 Cellular Phone
Gateway Solo 9550
If you can see a faint image of the desktop or the machine works with an external monitor, the either the screen inverter or the screen backlight has gone out. Start by checking the screen connections. The connection to the screen, screen to inverter and screen to motherboard. Connections can sometimes work loose. A loose connection generally causes the screen to go out entirely, rare but occasionally it can cause just the backlight to go. If the connections are good, then you will need to take it in to have the screen and inverter tested to find out which it is. If it turns out to be the backlight, you will have to purchase a new screen, screen are considered sealed units and just the backlight can't be changed out.
Jul 21, 2008 | Gateway Solo 9550 Notebook
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
The screen still displays the image but the backlight if off
you need to get the inverter changed out. Thats the part that changes DC to AC and powers the backlight
Jan 16, 2008 | Toshiba Satellite A135-S2276 Notebook
No backlighting
You need to repalce the backlight/Screen altogether, or have someone do it for you. If the backlight has cracked then no amount of reconnecting will get it to work. Try one of the many Laptop repairers online to get a quote
Dec 28, 2006 | Toshiba Satellite M35X-S163 Notebook
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
