Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
My computer doesn't recognize the SimpleDrive...
Hello, I plug or turn on my 500GB SimpleDrive USB 2.0 External Hard Drive and it starts turning the ligths on, then I hear it moves for a while and then stops, the computer does not recognize it....What can I do? All my info is there, I can't work with it!!! Anybody could help me please?
  • 979 Answers
Good day sir, hi, It looks to me that your simple drive is giving up on you. Im assuming that the correct device driver is loaded properly.
There are two major part that you may try to test, the interface board and the hard drive. Hopefully the interface board is the cuplrit.
Have you tried in on another PC, you can also remove the hard drive, and place it on another computer. If done properly, you can get your files stored in it. then buy an aftermarket USB hard drive enclosure (without the hard drive). to replace the simpletech enclosure.
Posted on Nov 20, 2009
    Scholar:
  • 56 Answers
Hello jajogeglez,
You may need to use another USB device, be it another flash drive to narrow down if it's just your Simpledrive that's causing this.
You can also update the USB devices under your Device Manger using the CD driver for your motherboard.
Hope this helps.
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
Cannot get computer to recognize my simpletech external hard drive. I have windows 7
A problem I commonly have is if the external drive is plugged in to a non powered usb hub the unit does not have enough power and will not be recognised, ensure it is plugged directly into the pc tower or if you have a laptop try an alternate usb port as some may not be powered.
Mar 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Not recognized
Make sure that the connectors are inserted properly. Try another cable or see if it mounts on another computer. If you need more help, please call HitachiGST Tech Support M-F 8AM to 6PM PST at 1.888.426.5214 and a technician will be happy to help you.
Feb 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
I have 500GB SimpleDrive USB 2.0 External Hard Drive, but currently i am facing some problems with it. When i plug it in to my computer, the computer says that unknown device. and it also does not come to...
I would unplug the external drive then shut down your computer. Plug the drive in(be sure the USB port is in good working order.)Turn the computer on. If it does not recognize the drive search online for tech support for that particular drive. Install any drivers or software. Be sure to find out if the drive is compatible with your operating software. Make sure all connectors are seating firmly and correctly. Make sure that everything is plugged in where it should be plugged in.
Feb 15, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Lost instruction booklet fo simpletech 250 ex hd
The drive is USB. To access the drive, plug it into a USB port of the computer.
The drive should be recognized by the computer.
I am not sure about Simpletech, however, most drives do not have an "instruction book".
What are you looking for in this documentation?
Dec 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Hello, I am having trouble with my usb ports. It does not recognize anything that I plug into the usb ports. I did a system restore and it still does not recognize the usb ports. It only recognizes it if I...
reinstall your usb controllers and handlers off the factory system disk that came with your system..something corrupted the files somewhere ...system restore wont replace deleted system files only restore user settings when you put the disk in it will have a section to restore drivers...select usb and reinstall then restart the system
Sep 28, 2009 | SimpleTech 500GB SimpleDrive Pro External...
SimpleDrive Will not Run
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Sep 23, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
528 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
