Acer aspire LCD problem
I have acer aspire 4720G laptop. when i press the power button, it works but no display at all. could this be a LCD problem on it???Please Help!Jheson
    Scholar:
  • 56 Answers
Hello zan_drx,
You can connect another lcd or monitor to your laptop to check if it's just the screen for your laptop.
Another possible scenario is it could be your video card, the RAM or the board itself that may need to be repaired or replaced.
Hope that helps.
Posted on Nov 20, 2009
    Sergeant:
    Champion:
  • 212 Answers
Try to plug in an external monitor. The laptop should detect it is pluged into a monitor and if the LCD screen is the problem you will know. Also look very close to the LCD. If you can see it working very faintly, the backlight is burnt out. Good Luck.
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
Acer aspire one no boot menu screen blank power light on no other lights showing except a brief flutter on when using power button when pulling power lead out display show flicker of light
sounds like your lcd inverter may have went out,,,thats a good chance ,,its what powers ur lcd backlight,,check acer website for support,,
Nov 03, 2010 | Acer Aspire One PC Notebook
I have acer 3050 is switch on but no display
Hi! Try to check if there is a hotkey to turn on/off lcd display. If none, try to power drain the machine by unplugging ac adapter and removing the battery.Press and hold the power button for 10 secs and then after that put the battery back and plug in ac adapter.Press power button and then check if you will see anything on the screen,if still the same then try to connect the laptop to a external monitor and then press FN+F5 to switch display to external monitor, if you see something on the ext monitor it means you are dealing with a faulty lcd on your laptop...Hope this helps...
May 20, 2010 | Acer Aspire 3050-1733 Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Webcam stopped working..
re instal its driver. you can look it on device manager driver stall or not.
Jun 28, 2009 | Acer Aspire 5610-4648 Notebook
Acer Crystal Eye Web Cam of my 4720G not functioning
hi..go and visit this web to find your needs>>>>(http://www.acer.com/worldwide/selection.html)>>>>good luck...have a nice day
Jun 14, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Acer Aspire 3680 Laptop
hi,
1, make sure that your laptop got power. how to do it ? it is easy, the power led (close to headphone jack) is on. and power button led should be on. Just in case you can't power on, please check ac adapter and power port on your laptop.
2. i assume you have power. now power it on and press f2 to got to bios. press f2 many times, it should make a beeps when you press it many times. once you get a beeps, press fn+right arrow to adjust the brightness of lcd. did you see something ? what i am looking is dark display.
If your display is dark, open the power cover (power cover is cover where you see power button), you need to remove 2 screws on that cover, on lcd hinges. After you remove power cover, you can see cable close to power button, remove it and check the display again, is it bright or still dark, if it is still dark it could be inverter or lcd.
if your power is on and you press f2 many times, it doesn't make beeps sound. it is called no post. Reseat memory and if this still not working, your motherboard is bad. if you have 2 memory installed, try 1 by 1. sometime the memory slot is bad, sometime memory is bad.
i hope this troubleshoot will help you to find out whats wrong with your laptop.
good luck
Aug 23, 2008 | Acer Aspire 3680 Laptop
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
