Question about Dell E173FP 17" LCD Monitor
My Dell E173FP monitor turns off after 2 seconds and won't stay on.
    Scholar:
  • 34 Answers
In those 2 sec can you see windows or boot screens?
if you put bright light at an angle close to lcd can you see a windows shadow
then .... (from a.n. other)
after two weeks searching I finally find doctor living stone
http://www.aplusperfect.com/articles/lcd_capacitor_repair
more fun with paulbtorrent
the takening the case bit off is like open your wallet a second time
after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!]
also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button ! come back all is not well mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmm
Posted on Feb 04, 2010
  • 400 Answers
Sir,
You are suggested to check the power cable of you monitor it might that any unusual setress on the cable have got lose inside the monitor. Sir this was the first problem another could be that you screen have got lose solidation on chip which mainly cause this problem. You screen can be repaired and it is cheaper to get so.
Posted on Nov 20, 2009
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 1684 Answers
SOURCE: Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 17, 2009
  • 1684 Answers
SOURCE: Dell E173FP monitor comes on for a couple seconds
The Dell E173FP monitors come in several versions but the problem you have is caused by the same thing, a power supply about to fail. Check our web site at:
www.ccl-la.com we have repair guides for most versions of the monitor. Check the last letter for the version, the letter will be lower case. On our site click on monitor repair and then the version of the E173FP that you have. If you don't want to do the repair yourself we do offer a repair service for $30 plus return shipping.
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 13, 2009
mace1mace
  • 1138 Answers
SOURCE: Dell E173FP 17 monitor went dark and not working. ...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
Posted on May 24, 2010
budmrtn
  • 11361 Answers
SOURCE: open dell monitor E173fp
See some examples here, just remove the stand first and start cracking it open at the bottom edge first.
http://www.lcdrepair.us/Installation.html
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 01, 2010
Monitor stays on for a few seconds then goes black
could be your wires or your moniter itself check those replace the wires and see what happens if it doesnt work just pm me
Feb 26, 2012 | Dell E173FP 17" LCD Monitor
I am trying to connect a second monitor a dell E173FP to my computer. I run Windows 7. My computer is not detecting the second monitor.
If you have a dual-head video card, you will need to go into display properties where you should see 2 monitors. One will be grayed out. You need to right-click on that one and tell the computer that it's connected. Then you can set it up.
Oct 27, 2011 | Dell E173FP 17" LCD Monitor
Monitor is in asleep mode comes on 3 seconds goes off how do i get it 2 stay on
Does the monitor do this with other machines? If no or unsure, do the following and see if the problem persists
1. click Start 2. Click Control Panel
3. In Classic View, find the Power Options Icon and Double Click. In Category View, click the Performance And Maintenance and then click on Power Options.
4. Under the Power Schemes Tab, click the drop down box next to "Turn off monitor" and change the time.
5. Click Apply/Ok
Dec 08, 2010 | Dell E173FP 17" LCD Monitor
The monitor only stays on for three seconds
I will assume that you already try this mnoitor with other PC and still get the same result, same with new VGA cable.
Then you will have to do some component level trouble shooting, common failure in these Dell monitors (made by BENQ) are due to poor solder joints and shorted out transistors (c5707/5706) in the inverter circuits. See pictures of failed Dell monitors for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see, otherwise you can get the replacement board from http://lcdrepair.us/powersupply.html
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
Dell E173FP monitor comes on for a couple seconds then the screen goes black. When i turn it off then right back on the same thing happens. Luckily it came on and stayed on after about 8 attempts at this....
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 13, 2009 | Dell E173FP 17" Flat Panel LCD Monitor
Dell E153FPd Power stays on but video goes off after 2 seconds.
3 ideas here. bad connections on the coils inside. the inverter board has gone bad, or bad capacitors on the power board or inverter board. all of witch should be serviced by a qualified service center.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Goes out
Please list the model number of your monitor.
Also is the power light flashing? What color(s)?
Unfortunately the symptoms you are describing tell me the inverter/power board inside your monitor needs to be replaced.
Mar 05, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Monitor Logo
1,064 people viewed this question
Alun Cox
