Question about Dryers
Drier keeps stopping with filter light flashes keep taking filter out of door and cleaning it but keeps happening it is the WTL 5400 model
    President:
  • 1,891 Answers
Try running the dryer off the vent . I think it will work ok . ( clean th vent or it may be too long .. ) m m
Posted on Nov 20, 2009
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
We have a tumble drier model DRCS68W. When we are using the machine the clean filter light keeps flashing every twenty minutes. I have tried cleaning the filter but the same keeps happening.
Did you clean out the access vent that leads to the outer wall which vents outdoors? The lint also exits through the back side of the machine too.
Oct 12, 2008 | Dryers
How to clean the bottom filter
Don't know how old your machine is but on my wtl5400 the bottom flap is opened by:
1. open the drier door
2. note small round button on the lower right hand side of the drum surround
3. press the button which will spring forward then
4. lower filter cover springs off giving acess to filter drawer
NB if the filter is over full the button will spring open itself as a gentle hint
NNB YOU CANNOT CLOSE DOOR WHILE THE BUTTON IS EXTENDED so take care door will only close when lower cover has been correctly replaced relocating the button flush with the front of the machine
Aug 28, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch WTL 5400 running, but not heating
I've just fixed mine. The heating element at the rear under the covers was broken - crappy design BTW!
Mar 18, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
88 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
