When I put the paper into the slot and press ''Print'', the paper bunches and stops. The the monitor says ''No paper.'' How can I fix this?
May u r linesensor is defective and need to be replace(line sensor is inside the carriage assy.
Posted on Nov 20, 2009
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Wrong cartridge error code on canon pixma mp780 printer
Reseating the print head is seldomly needed to be done.Press the Open Button (1) to open the Paper Output Tray (2) Raise the Scanning Unit until it stops. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.The Print Head Holder moves to the middle Open the Inner Cover 1.Open the Inner Cover 2.CAUTION: a. Do not try to manually move or stop the Print Head Holder.b. Do not touch any metal parts.Press the ink tank's tab (1), then remove it from the slot (2) IMPORTANT:Handle ink tanks carefully to avoid staining clothing or the surrounding area. Lift up the lock lever and take out the print head.Again, place the print head back in position and press down the lock lever. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot IMPORTANT:a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.b. If the ink tank is inserted in the wrong slot, perform two head refreshings.Close the Inner Cover 2.Close the Inner Cover 1.Pull the Scanning Unit Lever towards you to close the Scanning Unit.Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.Automatically Aligning The Print Head Position:Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].Press <Menu> epeatedly until [MAINTENANCE] appears.Press left or right arrow to select [AUTO HEAD ALIGN].Press <OK>. The print head position alignment pattern prints.Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete. Manually Aligning The Print Head Position:When automatic alignment does not work well, align the print head position manually.Load A4- or letter-size plain paper in the paper support or cassette.Select the paper source with <Feed Switch> button.Press <Menu> repeatedly until [MAINTENANCE] appears.Use left or right arrow to select [ALIGN PRINT HEAD].Press <OK>. A horizontal pattern is printed.Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.A): Column(0): Select pattern number with most solid image Press <OK>.Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].Press left arrow. A vertical pattern is printed.Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.(1): Bad example (Least solid box) 2): Good example (Most solid box) Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.Press <OK> Repeat steps 12 and 13 to adjust column N.
Oct 09, 2011 | Canon PIXMA MP780 All-In-One InkJet...
How to load paper in casio calculator HR-100TM
Put the roll on the arms "like a toilet paper roll on the extender", and pull it under. There is a slot, slip the paper into this slot, and press FEED until the paper reaches the ink.
Sep 05, 2011 | Casio HR-100TEPlus Calculator
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
Paper jam
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Make sure paper are not wet and stick to each other when you putting the bunch of paper snuffle it and shake it .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Sep 23, 2010 | HP PSC 1210 All-In-One InkJet Printer
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Back cover is open
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
document. See Solving print problems on page 6-15.
Print overrun
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Paper pulls to right and bunches up when loading
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
jasbo
jasbo
